New member Username: Turbo_ek9Post Number: 1 Registered: Mar-09 | My amp is a 600w max pioneer or kenwood. I know, how do i not know. I want a sub that will hit the deep @$$ bass lines in my music. I would like to hit that bass that makes you feel like you are going to $#!^ yourself. I dont have the power nor cash for that. My plan is to spend $150 for a sub to get close to what I want. My car is a 2000 civic hatch. I think i can stuff a 15" in it. some guidance would be appreciated. |
Silver Member Username: TurnmatRacine, Wi Post Number: 975 Registered: Feb-07 | The audioque SDC2.5 is $159 and that would get loud if put in the proper box. Otherwise you can save more money |
Gold Member Username: SomedonniedudeIllinois Braaap MX Post Number: 2457 Registered: May-07 | Give us the model number for your amp, without knowing the specs on your amp picking out a proper sub would be a pure guessing game. Also, do you have an enclosure already? Sealed or ported? And I don't think you will have enough power for an sdc. |
Silver Member Username: TurnmatRacine, Wi Post Number: 977 Registered: Feb-07 | Nvm i missed the max following the 600. Reading>Me If he could find a 15" sd he should be good with that power. Othwise give us a little more to go on like Donnie said. |
New member Username: Turbo_ek9Post Number: 2 Registered: Mar-09 | Its a kenwood 760w, i looked at it the other day. I just bought a house and am in the process of rehabing it. It takes all of my time, so i am sorry if i cant respond sooner. i have a tape measure with me at all times, but cant seem to measure the box in my car for you. I think it is 20x20x6. Audiobahn 12", got it 4 or 5 years ago for $75. might be a 400 or 600 watt. |
New member Username: Turbo_ek9Post Number: 3 Registered: Mar-09 | Im am idiot. Pioneer gm5000, 760w. |
Silver Member Username: TurnmatRacine, Wi Post Number: 982 Registered: Feb-07 | You could go with a 15" RE audio SR or 15" Incriminator audio 187 series or 15" Memphis audio power reference series |
Silver Member Username: TurnmatRacine, Wi Post Number: 983 Registered: Feb-07 | If you put anyone of them in the ideal box they have the potential to do what you want. You might want to take and have someone build the box for you. |
Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 6326 Registered: Nov-05 | for your budget.. just pick up an RE SE and then eventually throw more power on it |
Gold Member Username: Hittin1TEAM REVOLUTIONLake Charles... Post Number: 2829 Registered: May-07 | start saving and get a good sub amp combo a lil later on down the road.. JMHO |
Gold Member Username: HdubbTeam Revolution Post Number: 4059 Registered: Nov-04 | exodus audio tempest-x |
Diamond Member Username: WingmanaliveWww.stainles... .ecrater.com Post Number: 20127 Registered: Jun-06 | You need to save and find an Ava. |
Gold Member Username: LoudonPost Number: 2916 Registered: Jun-04 | i have a bnib ava sitting in my room .. to bad ud have to give up ur first born for it lol |
New member Username: Turbo_ek9Post Number: 4 Registered: Mar-09 | How much money do i need to spend to hit 15 or 20hz. I know the human ear cant hear it. Some of the music i listen to seem to have those low lines in it. I found an MBQuart for $130 that has a low frequency response. I dont have much knowledge on brands. I have an audiobahn right now, and want to hit lower lows and still be louder for about $150. Sorry i dont know what a RE/ SE or whatever else is. |
Silver Member Username: TurnmatRacine, Wi Post Number: 995 Registered: Feb-07 | Here is a link to RE audio's SE http://reaudio.com/specs.html#sp_se |
Silver Member Username: TurnmatRacine, Wi Post Number: 996 Registered: Feb-07 | Box build is going to play a large part on how you want the sub to sound. In the ideal box the SE can do what you want |
Silver Member Username: 420pimp2Post Number: 853 Registered: Jan-06 | How much are re se's. 12 inch |
Diamond Member Username: WingmanaliveWww.stainles... .ecrater.com Post Number: 20131 Registered: Jun-06 | You can hear 15-20hz. You more feel it than hear it though....... |
Silver Member Username: TurnmatRacine, Wi Post Number: 999 Registered: Feb-07 | You can get a re se for $190 on ebay. Not sure how much to buy from a dealer |
New member Username: Turbo_ek9Post Number: 5 Registered: Mar-09 | the se is only 34hz. will it still hit my low lows? |
Gold Member Username: TurnmatRacine, Wi Post Number: 1001 Registered: Feb-07 | that is the optimal box size and tuning for the sub. You can run the sub in a smaller or larger box and tune either up or down but it will affect the subs performance. I think that it will do what you are looking for it to do. |
New member Username: Turbo_ek9Post Number: 6 Registered: Mar-09 | thanks. now i will need help with tuning a box. |
Silver Member Username: M0nstarToledo, OH U.S. Post Number: 200 Registered: Dec-08 | im just curious... what music is it that you're lstening to that hits notes that low? |
Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 6339 Registered: Nov-05 | very few songs play down that low.. most are in the 40hz region.. unless your playing some SQ tracks ![]() |
Silver Member Username: M0nstarToledo, OH U.S. Post Number: 202 Registered: Dec-08 | ^ thats what i was thinking |
