Silver Member Username: PoundhardhehPalmerston, Ontario Canada Post Number: 140 Registered: Oct-08 | Hey everyone, I've been posting alot of topics up as most of you proboly know! But now I have finally narrowed it down! And I am going to try a sub by Fi Audio. I don't want the BTL because I'm looking for an SQL sub. I am interested in either a Loaded 18" BL or a 18" Q. I hear the BL won't hit the low's quite as nice but it will hit more frequencies. Also I know the BL's have a ton more power handling and the BL has a smaller minimum box requirement! If you say 18" Fi Bl. What options should I get for the BL? Thank you guys for all the help in my other threads!! ![]() |
Silver Member Username: PoundhardhehPalmerston, Ontario Canada Post Number: 141 Registered: Oct-08 | Or do you think just 1 15" in the biggest box they ask for? Because I can only give the 18" the smallest box it requires but I can give the 15" the biggest numbers it's looking for! |
Silver Member Username: PoundhardhehPalmerston, Ontario Canada Post Number: 142 Registered: Oct-08 | Now I'm considering the BTL actually. Is the jump from Bl to BTl a huge drop in SQ? If not I am going to get a 15" BTL |
Gold Member Username: Drant19DUB-C, TX Post Number: 1445 Registered: Aug-07 | to run the BTL you will need electrical upgrades. how much power do u have to work with? It would be safe to just do a Q with BP option if amp is over 1000rms. QUIT POSTING THE SAME CR@P!!! |
Silver Member Username: PoundhardhehPalmerston, Ontario Canada Post Number: 144 Registered: Oct-08 | I plan on a new alt, the big 3 and 1 or 2 kinetik cells. I have no amp at the moment. But I will get whatever the sub requires! |
Gold Member Username: TejcurrentPost Number: 1753 Registered: Apr-07 | I like the sound of the BTL. I would get the daily version with all the options. Give it 2500 watts or so and you should be good. With the electrical upgrades you say you're willing to do I would go with it over the BL. If you want to save the cash and just go 1500-2000w go BL Seriously though, please stick with one thread. |
