Bronze Member Username: Caraudioislikecrack
Post Number: 52 Registered: Nov-08
Posted on my o6zx1000.1 for a american bass vfl80.1.my kicker is used the vfl is new |
Platinum Member Username: Chaunb3400
All he does is catch t...,
Alabama
U.S.
Post Number: 14216 Registered: Jul-05
Posted on really no point in trading if you are happy with ur Kicker, I doubt you will see any gain in any area.. |
Gold Member Username: Nd4spd18
Philadelphia,
PA
Post Number: 9986 Registered: Jul-06
Posted on My guess would be he needs a 1 ohm amp |
New member Username: Craudi0
Post Number: 4 Registered: Mar-09
Posted on yeah, i would only do it if you need a 1 ohm amp, if not then i would just stick with the kicker if its doing the job |
