Range rover headunit codes
Username: Mazdasport
Can anyone please find the codes for a range rover head unit the numbers I've got are
AMR 2384
PU 98448 - 286-7639-09
Hope these help or can anyone help find other numbers off my radio.
Username: Regrooster
Post Number: 3555
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C7000000 + + + + on a label somewhere on the metal casing.
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM
