New member Username: KdogggPost Number: 3 Registered: Oct-08 | i have my L5 12 inch solo baric kicker subs which push 600 watt rms per sub...should my amp be 600 watt rms or should it be 1200 rms since there are 2 subs?? |
Gold Member Username: Nd4spd18Philadelphia, PA Post Number: 8802 Registered: Jul-06 | 1200w or more. If the subs are dual 4 ohm you need a 1 ohm stable amp. A 2 ohm amp if they're dual 2 ohm. |
New member Username: KdogggPost Number: 4 Registered: Oct-08 | they r dual 2 ohm subs...this amp is 1 ohm stable but i think ill hook it up 2 ohms...do u think this system will be pretty good? |
Gold Member Username: Nd4spd18Philadelphia, PA Post Number: 8813 Registered: Jul-06 | Yea you will have to wire to 2 ohms. But you will only get half the amps output. Really you need a 2 ohm amp. |
New member Username: KdogggPost Number: 5 Registered: Oct-08 | is there a certain amp that is 2 ohms?...cause most i see say if u wire it to 2 ohms its 1200 watt rms at 1 channel...so if i wire to 2 ohms wont it be pretty good? |
Gold Member Username: Nd4spd18Philadelphia, PA Post Number: 8832 Registered: Jul-06 | Kicker ZX amps..... If an amp is 1 ohm stable you only get half it's power at 2 ohms |
Gold Member Username: N2audioLawrence, Ks USA Post Number: 1658 Registered: Mar-04 | 1 ohm amps don't often drop 1/2 their power at 2 ohms. It's usually more like 3/4. You see a lot of amps that are ~1200 @ 1 ~800-900@2 ~500 @ 4 |
New member Username: KdogggPost Number: 6 Registered: Oct-08 | ya like the subs are 1200 rms together and is 2 ohm nominal impedence and the amp puts out 1200 rms @ 2 ohms |
Gold Member Username: Nd4spd18Philadelphia, PA Post Number: 8864 Registered: Jul-06 | If you get an amp that is 1200w at 2 ohms then you're good. |
Diamond Member Username: BestmankindPost Number: 22775 Registered: Oct-05 | for the kicker L5, i would get a kicker zx1000.1. its 2ohm stable and it can be bought fairly cheap on ebay and will give you the power you need to those L5s. i know a bunch of guys with that setup. its pretty good. not a fan of L5 but their system sound alright i guess. ![]() |
