RE SX
Username: Dan_white
Post Number: 28
Ordered a sx 15" dual 4 ohm the other day. Plan on putting it in a sealed box with around 1.85 maybe 1.9 cuft not sure. Im putting a rd 1000.1 to it wired at 2 ohms. I'm an impatient son of a b**** so if anyone has any experience... let me know would I should be expecting.
Oh yea, going in a ford stx f-150 with an extended cab but not with seats. I'm hoping it will beat my expectations.
Username: Loc_out
Team RE XXX
Post Number: 2577
I've never own a SX but what i've hear it doesn't like seal box.
Username: Basssquared
Kansas
Post Number: 2342
I've owned a pair of SX's i've heard an SX in both sealed and ported and i dont see why they dont recommend sealed for it because it still got plenty loud
Username: Frkkevin
Team DLSSuperNatural...
Post Number: 5687
they are not designed for sealed enclosures.
best bet is to use that room and port it
Username: Dan_white
Post Number: 29
lol with that room ported wouldnt that make it sound even worse than anything comming from a sealed enclosure? From personal experience is really what I'd like to know because I've already seen that they dont 'recomend' sealed enclosures for it. I'll admit I dont understand why, unless of course someone has seen first hand the caution for doing so.
Raycist, how many cuft did you give each sub when sealed and what size were they?
Username: Dan_white
Post Number: 30
doesn't seem like the sx has been too popular a choice...
anyone?
Username: Southernrebel
Monroe, Louisiana 3 DD3515s, 2...
Post Number: 6858
I have run the RE SX15 both ported and sealed. They DO NOT like sealed boxes.
Try it in a simple 3.5-4cuft box tuned around 35hz.
Also, why did you get the DVC 4ohm? Your amp is 1ohm stable.
Username: Dan_white
Post Number: 31
What do you mean by DO NOT like sealed boxes specifically? Ive already ordered the sub and ive always wanted an re sub, a 15 at that. I have the sealed box built and ready fitting the max amount of room in my small truck.
Username: Dan_white
Post Number: 32
Btw I feel like a jack***. I didnt realize the rd 1000.1 pushes 1000 at 1 ohm instead of 2....
Like I said though id like to know what exactly is so bad about this sub and sealed enclosures lol from my experience any sub will sound decent in a sealed box. Id like to know whats so different about this sub and maybe another matching my specifications.
Post Number: 6859
You will get little to no low end from that SX15 in a sealed box.
If you must stick w/ a sealed box, send the SX back and get an SE.
Username: Dan_white
Post Number: 33
thats what im looking for...
in that case, if anyone still reads this, with that set up what would be a better alternative? assuming I can return the sub.
Username: Redliner
Wilmington, Ma
Post Number: 4531
Like he said a se would be nice. A fI Q in sealed or SI mag would be nice. they both sound great sealed. It's like the alpha i have i tried it sealed, sounded like sh!t it has no range what so ever and just sounds like it needs something else. A ported box definetly fixed that one. Just build a new box if you want the sx you wont be dissapointed
Username: Frkkevin
Post Number: 5688
just build a ported box and save yourself the trouble.. either way you did get the wrong vc config
Username: Rovin
1 15 = 149.5 DBsTrinidad & T...
Post Number: 14257
worked with 10" & 12" not the 15" but expect to be happy with it ported , sub is NOT designed to play well in sealed ...if u wanted the quality of sealed the SE is better suited for that ....
Username: Dan_white
Post Number: 34
Am I not understanding something here? with less than 2cuft to work with porting a box would not be the right thing to do correct?
If so, I've heard of the si mags. How much rms would a 15 need sealed?
Username: Frkkevin
Post Number: 5690
i don't understand why you can't build a 4cubic foot box if the truck is an extended cab.. build a larger box and run that SX.. tune to 35hz and get an amp that will do power at 2ohm.. or buy another S d4 and a larger amp..
you can fit ported 15s in an extended cab truck...
Username: Loc_out
Team RE XXX
Post Number: 2589
Dan why do you like the SX?
Username: Dan_white
Post Number: 36
its not a normal extended cab. the 1.9cuft box is the most i can fit. i guess im looking at what other sub i should get.
Username: Frkkevin
Post Number: 5693
bucket seats and build a center console FTW
Username: Dan_white
Post Number: 37
lol what?
does anyone have any suggestions on some other subs?
Username: Frkkevin
Post Number: 5695
yes, the RE SE... i just sold 3 too.. none left unless you want 12s
Username: Dan_white
Post Number: 38
the re se looks like a great choice.
what other subs are just as good if not better for a sealed enclosure? i see the mag only needs 1.0cuft of space and idk if thats what im looking for, considering my box already built is 1.9 cuft.
Username: Frkkevin
Post Number: 5696
if you could fit the mounting depth.. RE XXX :-)
idmax
Username: Dan_white
Post Number: 39
what about the treo ssi?
Username: Frkkevin
Post Number: 5697
good subs.. around the same as the re ses
im willing to bet the ses might get a little louder though.. ive heard many setups with them and they really wang
