Best 4" Speakers
Username: 71_chevelle
Post Number: 130
I was wondering what do you think the best 4" speakers are??
I've heard MB Quart and Boston are good name brands but i'm just not too sure which ones to go with.
Here are a few that i've looked at are these good or no?!?!
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT%26item%3D 200256812949
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT%26item%3D 220287827659
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT%26item%3D 390000581362
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT%26item%3D 270283796898
Thank you!!
Username: Rovin
1 15 = 149.5 DBsTrinidad & T...
Post Number: 14251
er what car & where is this going ...cant u modify the speaker holes to fit a bigger speaker instead...
Post Number: 131
Its going under the dash of a 1970's bronco i dont believe there are any speaker mounting areas...also not sure if there is room for anything bigger than a 4 inch speaker.
It's what my buddy said he wants i told him 5.25" speaker minimum but he says "there probably isn't enough room for a 5.25" speaker"
Username: Nd4spd18
Philadelphia, PA
Post Number: 8596
If the car doesn't fit good speakers in the stock locations, make some boxes and mount em somewhere, or bust out the sawzall and make em fit.
Username: Nd4spd18
Philadelphia, PA
Post Number: 8597
BTW mounting speakers in a dash is an absolutely terrible location, there is no "baffle" so you will get no midbass whatsoever.
Post Number: 132
Ohhh ok ok i'll have to double check on the speaker location and how they're mounted. If a little box is built under the dash to house the speaker would that work just as well?? or is that what you're saying?? lol
Username: Nd4spd18
Philadelphia, PA
Post Number: 8599
Yep that would do it.
Username: Tatonka
-[Team Audible Insanity]-
Post Number: 2356
Yeah, 4" speakers aren't exactly the best, but for some people, they are the only option.
See about doing an enclosure for a bigger speaker.
Post Number: 133
Ok got it M.S.
Thank you very much!!!
That is an option I hope we have nick...but like you said it may be the only option unfortunately
Thank you!
Username: Redliner
Wilmington, Ma
Post Number: 4537
make some kicks and go 6.5, 4" speakers just dont sound great.
Post Number: 134
I will definitely suggest that idea to him Charlie.
Thank you for your input!!!
Username: Rovin
Post Number: 14254
^agreed with charlie ...
