Gold Member Username: Killerzracing71Post Number: 2295 Registered: Aug-05 | I have 46.5 wide 36.5 L 19 High Im trying to get a total of 10cubes after displacment 30hz Im not stuck to those mesurements just a rough mesure ment can i get 10 cubes |
Platinum Member Username: Nyyfan13Yanks Fan USA Post Number: 10430 Registered: Jul-06 | With those measurements, you get a total of just shy of 16cubes net using 3/4" MDF. As for design help, I'll leave that to someone more educated ![]() |
Gold Member Username: Killerzracing71Post Number: 2296 Registered: Aug-05 | awesomo I cant wait, and yanks you can finnaly hear my setup lol |
Platinum Member Username: Nyyfan13Yanks Fan USA Post Number: 10433 Registered: Jul-06 | You'll probably end up being done with yours first man lol. I'm having second thoughts on some stuff so I have no time table anymore lol. Good luck with the design bud |
Platinum Member Username: InsearchofbassPost Number: 10609 Registered: Jun-04 | 44.25 wide 15 high 28.25 deep 10.85 cf gross (internal measurements) minus .60 for the port and .24 for the subs. Make the port 15 wide 4.5 high 11.25 deep for a 30 hz tune. That should work for a subs up port back design. How deep are the subs and what is the real displacement of each? |
Gold Member Username: Killerzracing71Post Number: 2297 Registered: Aug-05 | 8" deep and Ive read they displace .2cu ft |
Gold Member Username: Killerzracing71Post Number: 2298 Registered: Aug-05 | 15x 4.5 = 67.5 sq" right thats kinda small wouldnt you say? |
Platinum Member Username: InsearchofbassPost Number: 10615 Registered: Jun-04 | 15 high 44.25 wide 28.75 deep (internal measurements) 11.04 cf minus 1.00 displacement for subs and port if the subs are .20 each (are they?). And im not sure how you want to brace the box but we will need to account for that displacement also. |
Platinum Member Username: InsearchofbassPost Number: 10616 Registered: Jun-04 | How much power are you going to give the subs? |
Gold Member Username: Killerzracing71Post Number: 2299 Registered: Aug-05 | FOr bracing Im gonna use the idea that a guy gave me, wooden Dowels for bracing I have a 1krms @ 2ohms to give them they are rated 600rms each do you have aim or yahoo mesenger? mine Killerzracing on both send me an IM if you can so we can talk more |
Platinum Member Username: InsearchofbassPost Number: 10617 Registered: Jun-04 | Heres the new box we talked about. I went with 140 square inches of port. 17 high 44.00 wide 28.75 deep (internal measurements) 12.44 cf gross 28 wide x 5 high x 18.25 deep port for a 30 hz tune. 1.94 cf port displacement plus .40 sub displacement. (if thats correct?) And stick your bracing in. |
Gold Member Username: Th3pwn3rI compensate... Post Number: 8745 Registered: Jul-06 | When is this project expected to be completed? I'm wondering how these things perform. |
Gold Member Username: Killerzracing71Post Number: 2300 Registered: Aug-05 | Next week onece I get payed Im going to get some Wood and Ill be set Heres a Vids of what these subs can do not mine but a guy I subscribed to a while back He just posted this VID http://www.youtube.com/watch?v=GDa2xrLq9lA 20 hz vid http://www.youtube.com/watch?v=kkNy8rBvX1M some other dude 300 watts each http://www.youtube.com/watch?v=cfMx3Y6YALk http://www.youtube.com/watch?v=lFea2IE2C78 |
