Bronze Member Username: Biggiesize92Howey in the hills, Fl Usa Post Number: 14 Registered: Aug-08 | hey i was wondering wat would be a better sub the 9512 ir the 3512 and im looking to make a sql system so like a all around better speaker thanks for the help |
Gold Member Username: JakeyplaysbassSt. Louis, MO / ASU Post Number: 3280 Registered: Jul-05 | That depends on how much power you have... |
Bronze Member Username: Biggiesize92Howey in the hills, Fl Usa Post Number: 15 Registered: Aug-08 | just like wat is a all around good speaker idc about power i got all that |
Gold Member Username: JakeyplaysbassSt. Louis, MO / ASU Post Number: 3283 Registered: Jul-05 | It STILL depends on how much power you have... Tell us that and well tell you what sub. |
Silver Member Username: QuirkySA, Texas Post Number: 310 Registered: Feb-07 | "idc about power i got all that" so then you have the big 3 upgrade with an HO alt and are able to push 1500wrms... then go with the 9512. |
Gold Member Username: Nd4spd18Northwest PA Post Number: 8152 Registered: Jul-06 | 9515 > both In fact this 9515 ![]() https://www.ecoustics.com/electronics/forum/car-audio/506923.html |
