Silver Member Username: DeadrabitPost Number: 627 Registered: Jun-07 | so almost every one had arrow ports. any reason for that? i mean... arrow or slot would be the same but it seemed like most of them spent a lot of time making arrow ports an AQ 15 HD3 hit 144db off of only 700wrms with 2 12s hifonics xxx running on 4k in a hatch got in the 149.somethings there was an other dude with 2 12 t2s in a trunk that got 149.9, he got first everything was door open at front dash. a guy had a wall with 10 10s and only got 148. big let down |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 17667 Registered: Jun-06 | Aero not arrow.![]() |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 17668 Registered: Jun-06 | It's all about air resistance and turbulence. |
Silver Member Username: DeadrabitPost Number: 629 Registered: Jun-07 | so are aero ports just all around better? |
Silver Member Username: DeadrabitPost Number: 630 Registered: Jun-07 | when it comes to spl i mean |
Gold Member Username: The_image_dynamicSan Diego, California Post Number: 4443 Registered: Dec-06 | Arrow ports direct sound toward the listener enabling very high SPL. You're looking at +20dB compared to slot ports. |
Gold Member Username: Tatonka-[Team Audible Insanity]- Post Number: 2056 Registered: Mar-07 |
There are actually a few reasons for that. Sorry if I get technical here. "Arrow" ports are actually louder because they direct air in the form of an arrow to the listener like brad said. They are very precise. You can point them anywhere, and that is where you will be loudest. The trick is to hire a plumber of some sort, and get him to run some PVC pipe from your box to your dash. Place the meter on your dash and you will immediately gain DBs. Of course, make sure all the fittings are sealed up correctly. The science behind it was created by a older scientist named "Johnny A-row" Hence where the name "arrow" ports came from. He was a master in Neurosoundoligyitus. He discovered this idea by rejecting the null hypothesis into his acoustical performance. They are still popular today. Hope that sums it up for you man. If I'm wrong on any of this info, please feel free to correct me. |
Silver Member Username: Hittin1Lake Charles, La. United States Post Number: 887 Registered: May-07 | i heard it was 5 Db. / arrow port. So would need 4 ports to get 20 extra DBZ! Isn't that the rule of thumb?!? |
Gold Member Username: Th3pwn3rI compensate... Post Number: 8450 Registered: Jul-06 | I think I'll run some arrow ports in my next SPL setup one day. What kind of arrows should I use? |
Gold Member Username: JakeyplaysbassSt. Louis, MO / ASU Post Number: 3261 Registered: Jul-05 | Rob ill trade you a bow and arrow for a 4 channel amp and cash... Its BNIB BTW, let me know. |
Gold Member Username: BasssquaredKansas Post Number: 2227 Registered: Nov-06 | Jake hold on to that for me i'll take it off yours hands i'm gonna be doing an SPL setup in my car and that bow and arrow would do wonders with my 4 10"s is the bow made of genuine horse hair??/ |
Gold Member Username: JakeyplaysbassSt. Louis, MO / ASU Post Number: 3263 Registered: Jul-05 | No... its carbon fiber with mink hair. It has a golden plated tip however that drives the ladies and dBs crazy. Its mostly for looks but adds around 10-12dB. |
Gold Member Username: BasssquaredKansas Post Number: 2229 Registered: Nov-06 | i would totally take it off your hands but they outlawed mink in my home town its a shame its not horse i would have been on it like a wetsuit on a Mexican oh well thanks anyways brohan |
Platinum Member Username: InsearchofbassPost Number: 10063 Registered: Jun-04 | Seriously now. Aero ports have an advantage of allowing more airflow with less port area because of the flared design that cuts back on resistance. Using them also cuts down on the length of the port which is also beneficial because you want to have a port with no turns for greater spl potential. The lower amount of displacement an aero port takes up can also be useful. You could use the flared idea on a slot port as well but I answered it according to a standard slot port design. |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 17671 Registered: Jun-06 | Boy were you guys bored last night.![]() |
Diamond Member Username: BestmankindPost Number: 22049 Registered: Oct-05 | hahahahahaha fukkking nick.![]() |
Gold Member Username: Nd4spd18Northwest PA Post Number: 8054 Registered: Jul-06 | " Arrow ports direct sound toward the listener enabling very high SPL. You're looking at +20dB compared to slot ports. " ![]() |
Gold Member Username: Th3pwn3rI compensate... Post Number: 8462 Registered: Jul-06 | Lol. I'm glad I didn't totally miss the rest of this lol. |
Gold Member Username: SomedonniedudeIllinois United States Post Number: 1893 Registered: May-07 | You guys were joking??? D@mn, I just bought a new bow and arrow set for nuthin... |
Gold Member Username: JkidderWorlds gunna end, In 2012 Post Number: 3713 Registered: Nov-05 | lmao. nice anyway 149.9 loudest at the comp? ![]() ![]() the cisco kid |
Silver Member Username: Evildoughboy08Toledo, OH US and A Post Number: 116 Registered: Jun-08 | i should totally get the drill out and go to town on my box and put aero ports in. its a p00p box anyways. i can't believe p00p got edited out. |
Platinum Member Username: Nyyfan1315 Mag USA Post Number: 10132 Registered: Jul-06 | If I read "arrow port" one more time today, I'm gonna stab an infant..... BTW, VERY helpful info Nick ![]() |
Gold Member Username: BasssquaredKansas Post Number: 2231 Registered: Nov-06 | arrow port John i expect you to make good on your word waiting to see it in the news |
Platinum Member Username: Nyyfan1315 Mag USA Post Number: 10136 Registered: Jul-06 | Lmao |
Gold Member Username: The_image_dynamicSan Diego, California Post Number: 4446 Registered: Dec-06 | 10-month-old baby stabbed in stroller Toddler stable; man with history of mental problems detained after attack Associated Press August 8, 2008- A knife-wielding man stabbed a 10-month-old baby in her stroller, critically injuring her, police said. Isabelle Avins was rushed to a hospital where she underwent surgery Wednesday night. She was listed in critical but stable condition, police spokesman Detective Brian Sessa said. At the family's request, the hospital on Thursday declined to provide further details. |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 17682 Registered: Jun-06 | You think you know someone.............. |
Platinum Member Username: Nyyfan1315 Mag USA Post Number: 10137 Registered: Jul-06 | Thats either very ironic/creepy or Brad can pull a fast one |
Platinum Member Username: Nyyfan1315 Mag USA Post Number: 10138 Registered: Jul-06 | http://www.parentdish.com/2005/10/06/stabbed-baby-makes-great-recovery/ A simple Google search solves everything. Terrible situation for that infant....Brad's date was a little off though |
Silver Member Username: DeadrabitPost Number: 631 Registered: Jun-07 | ill get pics up tomo and 1 vid |
Silver Member Username: Hittin1Lake Charles, La. United States Post Number: 907 Registered: May-07 | cool BLK |
Silver Member Username: RidinspinnasWindsor, Ontario Canada Post Number: 399 Registered: May-06 | hopefully tomorrow morning ![]() |
Gold Member Username: SomedonniedudeIllinois United States Post Number: 1894 Registered: May-07 | Is it morning yet? |
Silver Member Username: DeadrabitPost Number: 637 Registered: Jun-07 | stupid computer... every time i try to upload it frezzes |
Silver Member Username: DeadrabitPost Number: 638 Registered: Jun-07 | ok got a few pics it wont upload any other place other than myspace. don't ask me y http://viewmorepics.myspace.com/index.cfm?fuseaction=viewImage&friendID=81280944 &albumID=16703&imageID=32606136 http://viewmorepics.myspace.com/index.cfm?fuseaction=viewImage&friendID=81280944 &albumID=16703&imageID=32606142 http://viewmorepics.myspace.com/index.cfm?fuseaction=viewImage&friendID=81280944 &albumID=16703&imageID=32606155 http://viewmorepics.myspace.com/index.cfm?fuseaction=viewImage&friendID=81280944 &albumID=16703&imageID=32606157 |
Silver Member Username: DuckaShelby Township, MI United States Post Number: 349 Registered: Jan-08 | The arrow port on the first one looks hilarious! |
Silver Member Username: DeadrabitPost Number: 639 Registered: Jun-07 | ya i know! it was huge! he uses the same port and just moves it around with different boxes at every comp. 144 on 700 wrms is pretty good isn't it? |
Silver Member Username: DeadrabitPost Number: 640 Registered: Jun-07 | do u like the noodles in the wall? |
Gold Member Username: Naledge503Portland, Or Post Number: 4104 Registered: Jun-06 | ![]() ![]() ![]() |
Silver Member Username: DeadrabitPost Number: 641 Registered: Jun-07 | thanks |
Bronze Member Username: SnacksQuincy, Florida USA Post Number: 52 Registered: Jul-08 | aero ports must be really good but they look like sh!t. |
Silver Member Username: DeadrabitPost Number: 643 Registered: Jun-07 | i would say aero ports are really good but with the kind of numbers they were hitting i don't see anything to great |
