Sub makin noise
Username: Prozack52
Cincinnati, 2-audio puls...
Post Number: 400
i have two audiopulse 12 epics wired at one ohm to an ed nine.1 drivin tday with volume down and i hear a small clicking noise cant tell if something is hittin the cone or not, s like metal hitting something else the sub still sounds great but the noise is anooying im going to ohm them out after work just did not know what you guys thought
Username: Prozack52
Post Number: 401
cd player is set right bass is off sub control turned up amp gain is set to half low pass about 70-80 and bass boost is barely up on it so i cant imagine blowing just one sub and the noise is only in one sub can a coil being going bad in the one sub
Username: Basshead4life
Iowa
Post Number: 13
does the noise happen when the sub drops like when it hits a deep low note?
Username: Prozack52
Post Number: 402
doing it all the time
Username: Exige
CDT, Audiopulse Dealer
Post Number: 452
zack ill try and stop by later tonight. ill get you a replacement if somethings messed up
Username: Snowball123
West Allis, WI United States
Post Number: 905
bass boost shouldnt be on at all fyi.
Username: Somedonniedude
Illinois United States
Post Number: 1736
"bass boost shouldn't be on at all fyi."
How do you figure?
Username: Prozack52
Post Number: 403
bass boost on the amp is ok but on the hu its off
Username: Prozack52
Post Number: 404
so what you think it could be
Username: Tatonka
-[Team Audible Insanity]-
Post Number: 1862
"bass boost shouldnt be on at all fyi."
Not exactly. Some amps can produce a certain amount of "bass boost" without clipping.
Post Number: 1737
Pull it out of the box and free air it, have you thrown a DMM on it yet?
Username: Prozack52
Post Number: 405
no im dmm'in after work
Username: Prozack52
Post Number: 406
oops well sub came unscrewed on one side
Iowa
Post Number: 16
like 6 dbs Nick V of bass boost unclipped usually.
Username: Nd4spd18
Northwest PA
Post Number: 7829
" bass boost on the amp is ok but on the hu its off "
Epic fail.
" bass boost shouldnt be on at all fyi. "
X2
" Some amps can produce a certain amount of "bass boost" without clipping. "
Even if that were true, all bass boost does is boost one frequencey creating a peak in the response (bad sound), exact same thing a bandpass box does. (well, 99% of bandpass boxes)
