New member Username: GushybearPost Number: 1 Registered: Jun-08 | Hey there, I currently have an RD audio alpha 12(ported), and while it is very (Very) loud (running on an rd 1750 amp) I feel its not accurate enough in the quick stuff. So i've looked around and alot of people say a w7 is overrated / overpriced, and for SQ in this range to go for an Fi Q or an IDMAX. well I think i've settled on an IDMAX, but cant decide if i wanna go with dual 10's or dual 12's. They will be sealed, and i listen to lots of rock but probably a third of the time it'd be hip-hop and bass intense music. First question is will my 1750 amp be enough to run a pair of IDMAX's(at 1 ohm i'm assuming... dont subs have better power handling at 2 ohms because of less heat?) ?? Secondly, in terms of overall output, would 2 IDMAX 12's with about 700watts each@1 ohm in a sealed box be comparable to a ported (34hz) alpha 12 ? Thanks for any input, and if you think i should switch the amp, do you have any suggestions that are moderately priced ? |
New member Username: GushybearPost Number: 2 Registered: Jun-08 | OOPS! also, its in an SUV, but i really want to minimize the space i'm taking up in the trunk. my stock alternator is 150amps, will this be sufficient? |
Silver Member Username: Hittin1Lake Charles, La. United States Post Number: 457 Registered: May-07 | http://www.imagedynamicsusa.com/manuals/iDMax/iDMax12D4V3.pdf the IDMAX manuel says sealed is recommended for most users... I've only heard them ported... They get Low and loud... I believe the Freq resp. is 5-100 Hz... 1750 Wrms should push them nicely.. I would recommend a 250 amp alt, but 150 amps is a strong stock alt. I dont think you will be getting the full 1750 with it though.. good luck and yes (imo)they will be comparable to the single ported alpha.. |
New member Username: GushybearPost Number: 4 Registered: Jun-08 | I think this amp is slightly overrated, and espescially at 1ohm its gotta be hard on the electrical system. and with the stock 150A alt, i'm guessing @ around 12V under load, and assuming i'm getting 100A charging power usable while the car is moving, thats 1200w conservatively... so a realistic 600+ watts getting to the subs, which should be enough. Has anyone had any issues with an upgraded alternator and warranty? |
Silver Member Username: Hittin1Lake Charles, La. United States Post Number: 464 Registered: May-07 | haven't need warranty....... yet! |
