8's vs 15
Username: Timbuc
Post Number: 19
Same brand. Which will be louder (3) 8 vs (1) 15?
Username: 04redmach1
Columbus, GA USA
Post Number: 1913
Depends. Which subs are you looking at? Same power? For daily or a f@rt machine?
Kevin
PS: I can't believe we can't use the word -F A R T- WTF?
Username: Insearchofbass
Post Number: 9230
one 15 is more cone area...and probably cheaper than three 8's if all the subs considered are the same brand and line but are you planning on competing
Username: Cblaze
Rock island, Tenesssee Us
Post Number: 2098
1 15 will be louder
Username: Hdubb
Team Revolution
Post Number: 3685
id go a 15 imo or 3 10s
Username: Deadrabit
Post Number: 389
if each sub has the same amount of power.. then the 8s would have 3 times the power... ?
Username: Naledge503
Portland, Or
Post Number: 3612
1 15" sub has more cone area than 3 8's. So if all variables (power, tuning, etc..) are the same, in theory, the 15" should be louder.
A pic is worth 1000 posts!!
Post Number: 16649
To me, why would anyone use multiple drivers if one suits the purpose? Amp, wiring, box, ect.....
The K.I.S.S. theory rules this one.
Username: Mark872
2 Type X 12s, Hughes S..., Texas
Post Number: 292
How do yall figure that one 15 has more cone area then 3 8s? Not being an azz..just want to know. cuz i would have just thought that 3 x 8 = 24. 24>15.
Portland, Or
Post Number: 3615
http://www.caraudio.com/forum/showthread.php?p=3394881#post3394881
http://208.110.132.9/classes/idbl/conversion_chart.php
Username: Timbuc
Post Number: 20
Thanks for the response guys, Ok here is my option (3) 8w7 vs (1) 13w7. I know, I know JL ;-). Both set up will being feed by a 1000/1. By the way the way both will be ported. I am going for a daily application, also if this would help I have Boston Z5 in the dash, and Boston Pro 4's in the kicks and in the rear powered by a 300/4. Many thanks guys.
Post Number: 9231
"To me, why would anyone use multiple drivers if one suits the purpose? Amp, wiring, box, ect.....
The K.I.S.S. theory rules this one."
depends if he wants to compete and that can limit your cone area...and if he competes in say iasca he would be limited to three eights or two 10's...(tens being more cone area) in the 160 square inch class
Username: Timbuc
Post Number: 21
Hey Sean, I am not competing. Just looking at options. So from your view being I am little green in this area. If you throw out the K.I.S.S theory. What would you do. So teach me something here. 3*8= 24"vs 15" am I am missing something here
Post Number: 9233
ok what you would do is take the woofer size cut it in half and multiply by itself twice and multiply it by 3.14 and you get the square inches of the speaker...so one 8 would be 4 x 4 x 3.14= 50.24...so three eights would be 150.72 and one 15 would be 7.5 x 7.5 x 3.14= 176.625...or as iasca calls it 176.63
Username: Timbuc
Post Number: 22
Just read up on it. Thanks
Post Number: 9234
yw
Username: Mark872
Post Number: 293
So that means that 2 8s would be 100.50 and a 15 is 176.63. So one 15 would almost be twice as loud as 2 8s??
Username: Rovin
Post Number: 13768
if u have space for 1 15 then u can also do 2 10s or even 2 12s ...
Username: Nd4spd18
Northwest PA
Post Number: 7519
Haha you fail at math.
