Subwoofer Wire Repair
Username: Ironslave
Offutt AFB, Nebraska U.S.A.
Post Number: 561
So i took my sub out of my box cause the box was totaled in my car accident and to my suprise the wire that gos from the terminal to the voice coil on one of my subs was Broken off.
The problem is that the wire broke on the terminal connecting to the Voice coil and the peice of wire in the terminal hole wont come out, i sat there for 2 hours with a soldering iron trying to take it off. I ended up usin a push on connector to re attach the wire and topping it off with some gorilla glue, i found out the head unit dosent work as expected either. so i cant afford to get a new head unit and replace the sub the same time. is there a way i can source new wire for when this thing breaks again?
Username: Surferdude9371
Im BTL Bumpin
Post Number: 765
i always solder it and it works fine what kind of solder are you using?
Username: Hdubb
Team Revolution
Post Number: 3392
wht kind of sub is it? and its called a tinsel lead. =) you can send the sub in to get fxed or just buy a recone for it and if you feel confident recone it yourself. =)
Username: Nd4spd18
Northwest PA
Post Number: 6665
Recone time........
Username: Bernymac
Cambodia
Post Number: 3762
You needed to use desoldering braid.
http://www.radioshack.com/product/index.jsp?productId=2062744&cp=2032058.2032236 .2032313&pg=2&parentPage=search&sr=1&origkw=solder&kw=solder&parentPage=family
get the iron hot, then put the braid against the part you want to desolder, and then put the iron above and it would remove all of the solder.
Username: Ironslave
Post Number: 564
i will try the braid today, i would like to get this sub running again as it has served me well for almost 2 years
