Where to get a 6 ohm sub
Username: Cblaze
Rock island, Tenesssee Us
Post Number: 1808
i got a powered sub i wanna take the amp out of use it .need a sub that can handle 120 watts at 6 ohms preferabbly nothin smaller than a 10
Username: Philly306
New quote coming soon, North carolina
Post Number: 898
Why does it have to be 6 ohm?
Username: Cblaze
Post Number: 1809
thats what the amp needs
Username: Philly306
Post Number: 899
The amp needs?
Can your amp not handle a 4 ohm load?
Username: Cblaze
Post Number: 1810
its a powered sub in my room on my surround reciever.i called the company and told them i wass going replaace the sub.they said 120 watts @ 6 ohms.i doubt it could handle that i do not know.i found a sub that is 6 ohms on part exxpress but it only is rccomended to play down to 40 hz.i wanna tune to 30-32 hz
Username: Ska
Post Number: 513
or a 2 ohm?
Username: Thumpinwith8s
2 RE8s,PG Xenon 400.1, 135.5dbs!!!!
Post Number: 1076
I've never heard of a 6ohm amp or sub,
Username: Ska
Post Number: 514
this is for home theater?
Username: Philly306
Post Number: 900
JL audio made a DVC 6 ohm(not what you need i know) sub
But im sure your amp will work with a 4 ohm load. that will give you plenty of options
Username: •cam•
BC Canada
Post Number: 2019
Sometimes they're in home audio speakers. I doubt you'd kill it with 4 ohms. I have had a 4 ohm eD EHQS 12 on my Sony home amp, which is rated at 6 ohms, forever now. Plus I crank that sh!t way up past distortion sometimes. There are absolutely no problems.
Username: Shortysetnies
Rock Vegas, NC US
Post Number: 2213
some audiobahn subs are dual 3s
Los Angeles, CA
Post Number: 18734
its okay to go below ohm load. i bet a 4 ohm load would work.
hell why not just wire it at 1ohm and see what it does. lol.
jp about the 1ohm but 4ohm should be fine.
Username: Its_bacon12
Hfl, Ny Usa
Post Number: 1265
if its HT, i doubt it'll go below 4 ohms. why not just get an 8 ohm sub?
Username: Treez
Post Number: 281
U can try finding the jl w0's, they're on ebay..
Their rms is 75 watts and their peak is 150 . They come in single 4, 8, 12 ohm...
Username: Cblaze
Post Number: 1811
if i knew i could wire it to 4 ohms id just throw a ehgs on it.ill try it.
Los Angeles, CA
Post Number: 18759
chad lee is not responsible for the claims and opinions he makes on this thread.
Rock Vegas, NC US
Post Number: 2218
lol. A disclaimer from chad
Username: Cblaze
Post Number: 1812
lmfao rotfl i got it hooked up to a 4 ohm load no smoke yet
A pic is worth 1000 posts!!
Post Number: 14121
Just don't go HEAVY with the volume.
Username: Somedonniedude
Illinois United States
Post Number: 1025
I had an older model of these and there not half bad.
http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/1422483/vpcsid/0 /SFV/30046
Username: Cblaze
Post Number: 1813
ima prolly get that sub soon.but right now i figured out a way to break my sx in a lil.i got it hooked up in my room.hopefully in 2-3 weeks ima have the suv or extended cab truck to put it in
Post Number: 1027
^^^^That price is for a pair btw.
Username: Cblaze
Post Number: 1815
i noticed that
Username: Winterfreshpimp
Chisago, MN America
Post Number: 608
kenwood JL and audiobum all make 3 ohm subs, mostly double 3's
