Silver Member Username: Snowball123West Allis, WI United States Post Number: 159 Registered: Oct-07 | but do you think these would run good off a kicker zx200.2? or what im asking is if these are decent speakers? http://cgi.ebay.com/MB-QUART-RVF-213-REFERENCE-SERIES-5-25-COMPONENTS-NEW_W0QQit emZ140200322165QQihZ004QQcategoryZ32818QQssPageNameZWDVWQQrdZ1QQcmdZViewItem |
Gold Member Username: Denali_on_22sPost Number: 3657 Registered: Feb-06 | yeah that amp should be fine with them |
Platinum Member Username: BestmankindRD 1000.1D with SI MAG... Post Number: 17128 Registered: Oct-05 | ^^^^x2 |
Silver Member Username: Snowball123West Allis, WI United States Post Number: 161 Registered: Oct-07 | or do you think some diamond audio d6's will be better. theyre just a little more expensive. |
Platinum Member Username: BestmankindRD 1000.1D with SI MAG... Post Number: 17155 Registered: Oct-05 | hey only one question per thread please. lol. jp man. anyways if i was you, i'd spend a little more and get the diamond d6's. honestly i haven't heard either one but from the reviews on the diamond speakers, i would take it. like i said, that is if i was you. lol |
Silver Member Username: Snowball123West Allis, WI United States Post Number: 162 Registered: Oct-07 | yeah my friend has them too. i prolly will just spend the little extra to get those. thanks man. |
Gold Member Username: Loc_outSanta Ana, Ca Resonant Eng... Post Number: 1613 Registered: Feb-05 | Snow which Dianmond d6's? |
Silver Member Username: Snowball123West Allis, WI United States Post Number: 164 Registered: Oct-07 | http://cgi.ebay.com/DIAMOND-AUDIO-D651S-5-25-D6-COMPONENT-CAR-SPEAKERS-NEW_W0QQi temZ150208669526QQihZ005QQcategoryZ32818QQssPageNameZWDVWQQrdZ1QQcmdZViewItem |
Gold Member Username: Loc_outSanta Ana, Ca Resonant Eng... Post Number: 1615 Registered: Feb-05 | Snow i have the D661S and they sound good. Chad has hear them his just acting like D1ck. j/k |
Gold Member Username: Nd4spd18Northwest PA Post Number: 5664 Registered: Jul-06 | Get the diamonds...... i do not like the sound of mb quarts tweeters. |
Silver Member Username: Snowball123West Allis, WI United States Post Number: 177 Registered: Oct-07 | alright then. which would you suggest. silk or aluminum tweeters? |
Gold Member Username: Nd4spd18Northwest PA Post Number: 5676 Registered: Jul-06 | Definetly silk |
Gold Member Username: SouthernrebelMonroe, Louisiana 2 DD3515s, 2... Post Number: 5846 Registered: Mar-04 | Phoenix Gold Radials. Just tame the tweets alil and you are golden ![]() |
Silver Member Username: Snowball123West Allis, WI United States Post Number: 182 Registered: Oct-07 | what is the difference?? my friend has aluminum and says he likes the sound of those better. |
Gold Member Username: Big_edge_headMilwaukee, Wisconsin MY SUB... Post Number: 1213 Registered: Mar-07 | Its just personal preference. I just like how aluminum tweeters sound. |
Silver Member Username: Snowball123West Allis, WI United States Post Number: 184 Registered: Oct-07 | is silk like a softer sound or something? im just making sh*t up. haha |
Gold Member Username: Nd4spd18Northwest PA Post Number: 5681 Registered: Jul-06 | Metal tweeters usually sound really f*ckin bright...... not a good sound Of all the best sounding tweeters, most are silk |
Gold Member Username: Big_edge_headMilwaukee, Wisconsin MY SUB... Post Number: 1215 Registered: Mar-07 | Aluminum is stiffer so if flexes less which, which means its harder to distort. They are a bit more accurate. they will sound a bit more harsh, not all though. Silk have a warmer sound to them. They are bit more easier on the ear. I like aluminum because i like high highs. lol |
Silver Member Username: Yukhui4 15 AA Havocs, Memphis 4kw!! Post Number: 859 Registered: Jan-06 | Ask away with your questions related to car audio, thats what the forum is for. My friend has two sets of them off a kx350.4 and they sound pretty damn good for the money. |
Gold Member Username: Nd4spd18Northwest PA Post Number: 5684 Registered: Jul-06 | Haha I like good high notes also...... but I like them to sound smooth not harsh |
Platinum Member Username: BestmankindRD 1000.1D with SI MAG... Post Number: 17184 Registered: Oct-05 | silk ftw. |
