Bronze Member Username: Blaze_upPost Number: 13 Registered: Nov-07 | Yeah i know its nothing compared to sum of your systems but im happy with it. ![]() ![]() ![]() ![]() |
Silver Member Username: ImalikSD2.5......ED9.1=Boom, New Jersey Lord Protect... Post Number: 563 Registered: May-06 | Looks good, clean install |
Silver Member Username: BoomtankRochester, NY USA Post Number: 398 Registered: Oct-06 | As long as you like it thats all that matters! |
Silver Member Username: Cplaya280Quakertown, PA USA Post Number: 809 Registered: Oct-05 | lol dont tell me thats a sony xplod amp. looks small as ish too... |
Silver Member Username: Mj23dynastySome where 12 wangin o..., The Mighty J... USA Post Number: 465 Registered: Oct-07 | Man wether its sony or sundown as long as ur happy thts all tht matters for real for real so I'm not going to knock any1's set up bcuz what I have may be great 2 me but trash to some1 else. What kinda subs are those btw |
Silver Member Username: Cplaya280Quakertown, PA USA Post Number: 811 Registered: Oct-05 | haha yea tru story dwight. ma bad blaze up...everyone has their own perferences and not everybody has money to spend on car audio. as long as your happy thats what sup. |
Gold Member Username: HdubbTeam Revolution Post Number: 3039 Registered: Nov-04 | actually like the little amp. even though i dont know the performance of it i like the way it looks. what kind of subs are those? |
Silver Member Username: TreezPost Number: 116 Registered: Aug-06 | Tight install |
Bronze Member Username: Igor_xxxPost Number: 28 Registered: Sep-07 | The subs are Kenwood KFC-W3514DVC.i'm thinking of getting this subs for myself so how do they hitt and whats the xplod RMS? |
Silver Member Username: Dubmc23Rapid City, SD USA Post Number: 170 Registered: Sep-07 | very clean...hope u like it bro |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 11345 Registered: Jun-06 | Is that a custom sealed box? Did you make it? |
Silver Member Username: CblazeRock island, Tenesssee Us Post Number: 592 Registered: Sep-07 | im suprised somebody put that much work into xplod,but its your ears hearing it not mine,nice install tho |
Gold Member Username: JkidderGunshine , State Flawda Post Number: 2815 Registered: Nov-05 | seatbelt goin across doesnt look good but if u have the seats folded up always it wouldnt matter |
Silver Member Username: Yukhui3 15 AA Havocs, Memphis 4kw!! Post Number: 791 Registered: Jan-06 | You ~may~ find your system a lil bit louder with the subs facing the rear of your car. Worth a try at least.. |
Bronze Member Username: Blaze_upPost Number: 14 Registered: Nov-07 | the subs are kenwood KFC-W3514DVC 1500watts each, the xplod amp is giving each one 600 watts i think. dont know bout the rms. they do sound louder facing the rear but the bass is a lot cleaner face in, not top of the range but they they do sound insane! can any1 fill me in on what class d technology is? |
Bronze Member Username: Blaze_upPost Number: 15 Registered: Nov-07 | the amp is a sony xplod xm1s by the way, ment to be powerful for there laughable size. |
Gold Member Username: BernymacTurtles have four legs Post Number: 3482 Registered: Sep-04 | Mind as well read it all. http://www.bcae1.com/ampclass.htm |
Bronze Member Username: Blaze_upPost Number: 16 Registered: Nov-07 | Cheers BernyMac, i guess class d is the way to go for powering subs. |
Gold Member Username: CtmikeCt. Post Number: 5443 Registered: Feb-06 | looks clean at least and probably only cost you about $200 or so? and to let you know, at most your subs are seeing about 250w each, at most. which is good since your subs are rated at 190wrms each. good tip for you to learn, always go off RMS and never 'max' or 'peak' power ratings. |
Bronze Member Username: Blaze_upPost Number: 17 Registered: Nov-07 | $200?!?! i wish, the amp was $600 and $300 for each sub. thats australian money though. the peak power is only for a short burst ay? and is 250w a good amount to power em or should i be looking at upgraging? |
Bronze Member Username: Igor_xxxPost Number: 31 Registered: Sep-07 | That subs are not 190rms each, they are 380wrms each.see with your own eyes if you dont believe me http://www.kenwood.eu/products/car/speakers/component/KFC-W3514DVC/details/ |
Bronze Member Username: Blaze_upPost Number: 18 Registered: Nov-07 | what do you think of the subs? good ones? and what amp would you recomend to have em poundin? |
Bronze Member Username: Igor_xxxPost Number: 32 Registered: Sep-07 | a friend of mine had one of these subs and he had it powering with 500rms at 2ohm and the sub never blow or damaged and hitt very hard for the money.believe me they can take more then 250w |
Bronze Member Username: Blaze_upPost Number: 19 Registered: Nov-07 | sweet, thanks Igor Stojcevski time for a new amp i think![]() |
Bronze Member Username: Igor_xxxPost Number: 33 Registered: Sep-07 | No problem just dont't push them to the max if you run them around 500rms each.they can take it but who knows....gave them 400rms each.you know what i mean right? |
Bronze Member Username: Blaze_upPost Number: 20 Registered: Nov-07 | yeah i know what ya mean. |
