Polk Audio db124DVC Or Polk Audio MOMO MM2124DVC
Username: Hddvd
I am setting up my first car audio system. I am stuck in the middle of choosing these 2 subs. I will be getting 2 of which ever one i choose. I am just looking for something with good SQ and also loud. If someone can recommend which one to choose or even another brand within the same price range that would be great. Thanks for any help.
Here is a link to the subs:
http://www.sonicelectronix.com/item_6852_Polk+Audio+db124DVC.html
http://www.sonicelectronix.com/item_6854_Polk+Audio+MOMO+MM2124DVC.html
Username: Extrmndor3
Post Number: 7109
momos... they just sound really good
Username: Hddvd
I have an installer friend that works at best buy. He recommended that i get this amp to go with the momo subs. What do you guys think?
Rockford Fosgate - http://www.bestbuy.com/site/olspage.jsp?skuId=8265548&type=product&id=1170289779 572
Username: Hddvd
Sorry the link is weird.
Product Features
* 1000W peak output @ 2 ohms
* 750W peak output @ 4 ohms
* 500W RMS (continuous) @ 2 ohms
* 250W RMS (continuous) @ 4 ohms
* Variable LP 40-250Hz crossover
* Dynamic thermal management prevents overheating
* Bass boost; on-board Punch EQ
* 4-gauge power and ground input
Username: Denali_on_22s
Money man, blowin
Post Number: 3017
if you go with polk go with the SR series... they are nice woofers... great SQ and get pretty darn loud
Username: Hddvd
i wish i could. but that is waaay out of my price range.
Username: 420alldaylong
Post Number: 2868
Out of the two subs above go MOMO.
Is this the amp you are talking about.
Username: Kyle_lowe
Post Number: 627
dont count out those db's
a long while back my friend didnt want them anymore so i gladly took them off of his hands
they were in that prefab box that polk makes
well that box was really freaking big so i made a sealed box for them and ran them at 2 ohm an a8000t and they had surprisingly good sq. they far exceded what i expected them to do. 134.3 on the dash on a tl.
thats my story
there is a thread somewhere with all of the pics i posted...but it is archived
Post Number: 2869
My bad the link didn't work but the amp is a Rockford Fosgate P1000-1bd $599.99 at best buy.
ravindra maathura
If that is the price your paying PLEASE DON'T there is much better for less.
Username: Hddvd
dont worry. I work at best buy. I get over half off the price for that amp.
Post Number: 2870
$300 is still to much for a Rockford P1000-1bd.
If you get discount prices go with a Alpine Type R 12" dual 2ohm and this amp below.
Free shipping on this amp and way underated.
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=18424
Username: Snarl2004
Audioque 12 SD2.5s, Earthquake P...
Post Number: 1823
umm each of those subs are dvc4ohm. IF you wire them both together you can either get a 1ohm or 4ohm final independence load. Each sub is rated for 400rms so you need 800rms or so. that amp isnt 1ohm stable and only does 250rms at 4ohms.
Say you get that amp for 1/2 price thats still 300. You could get any of these amps:
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=4675&C FID=6661080&CFTOKEN=e46b7ee087c6f00f-1C30FE91-1422-7C6E-501CE39C42C0223C
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=4210&C FID=6661080&CFTOKEN=e46b7ee087c6f00f-1C30FE91-1422-7C6E-501CE39C42C0223C
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=373&CF ID=6661080&CFTOKEN=e46b7ee087c6f00f-1C30FE91-1422-7C6E-501CE39C42C0223C
Post Number: 2871
I would take the Rockford T5001bd over those amps above.(but thats me)
Post Number: 7110
get 2 momos..
and a hifonics bxi1606d just keep the gains down and no bass boost
Username: Hddvd
actually it is stable at 1ohms.
These are the specs from the rockford website:
continuous power
250W x 1 @ 4-Ohms RMS
500W x 1 @ 2-Ohms RMS
1000W x 1 @ 1-Ohm RMS
