Sudden loss of bass
Username: Theweasel
2 12 FI SSD, Colorado U.S. of A
Post Number: 1133
i turned my music on today and it seemed like the bass is about as third as loud as it usually is. all my amp settings and hu settings are the same and it doesn't sound bad, just quieter. i've checked the power, ground, rcas, and speaker terminals on the amp and the box and they are all fine. any ideas? thanks
Username: Loudon
Post Number: 1915
take that sub out of the box and make sure of ur connections
Username: Theweasel
Post Number: 1134
fack i hate doing that, i've got so many friggin holes where the screws are
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 13100
ur just getting use to the bass....oh well time for an upgrade
Username: Tejcurrent
Post Number: 774
^My thoughts exactly.
Username: 30hrtz
Raleigh, Nc U.s.a
Post Number: 111
its a conspiracy by all the car audio companies.System will slam for a few days or weeks then 1 day the bass is gone.or much less.like at low volumes especially.bass you could feel now you can barley hear.nothing has changed and nothing is broken.I know Im dealing with that now myself.If you ever figure it out let me know.Ive seen it happen for 15 years off and on.addictive stuff,you just keep upgrading everytime it happens.Being hooked on bas sucks!My local audio shop say they hav seen it too at times and cant figure it out either.good luck.
