Bronze Member Username: O0airjordan120oMN US Post Number: 77 Registered: Sep-07 | truely sounds bad. idk. its sounds like its leaking. when it hits certain lows it makes a pfffffffff noise. i hav a 4inch diameter port. 10 inches deep in a 2.03ft3 |
Silver Member Username: Greeney1888Clover GroveIm rich btch... Post Number: 392 Registered: Feb-06 | what did u seal the edges of your box with? |
Bronze Member Username: O0airjordan120oMN US Post Number: 78 Registered: Sep-07 | woodglue and i sealed the port with silicone. its not leaking air. but sounds like it is.. out of the port. |
Gold Member Username: InsearchofbassPost Number: 6596 Registered: Jun-04 | https://www.ecoustics.com/electronics/forum/car-audio/391980.html |
Gold Member Username: FrkkevinResonant Engineering..., Fort Worth... Email Post Number: 3590 Registered: Nov-05 | its port noise my friend.. you don't have enough port area |
Gold Member Username: InsearchofbassPost Number: 6597 Registered: Jun-04 | same as i told him in the link to the other post |
Bronze Member Username: O0airjordan120oMN US Post Number: 81 Registered: Sep-07 | i have a 4 inch pvc pipe... how much bigger do i need to go? |
Platinum Member Username: Rovin4 10 Pioneer... Post Number: 12259 Registered: Jul-05 | a 4" port is about = to 12sq" so since ur box is 2cuft thats about 6sq"\cuft which is tiny ..... |
Bronze Member Username: O0airjordan120oMN US Post Number: 82 Registered: Sep-07 | really? how many sq" do you usually need per sqft?? |
Gold Member Username: FrkkevinResonant Engineering..., Fort Worth... Email Post Number: 3597 Registered: Nov-05 | 16inches is a good number.. anywhere from 12-16per cube is fine though |
Bronze Member Username: O0airjordan120oMN US Post Number: 83 Registered: Sep-07 | so i should put in another 4 inch port? |
Platinum Member Username: Rovin4 10 Pioneer... Post Number: 12260 Registered: Jul-05 | i agree between 12-16\cuft is good .closer to 12 for more sq u can add another 4" if u can get the correct length to fit in ur box .... |
Bronze Member Username: O0airjordan120oMN US Post Number: 84 Registered: Sep-07 | im using that port calcolator and it says i shuld make the length 26 inches if i put 2 4In ports in.... is that total legth? or 26 per port??? |
Gold Member Username: InsearchofbassPost Number: 6600 Registered: Jun-04 | thats per port |
