Bronze Member Username: ShorterthanrichPost Number: 78 Registered: Apr-06 | Hello again all! I'm helping a friend buy new speakers for his wifes car. She has a 2000 dodge Neon. He mostly needs two new front speakers, but may look into rear ones as well. The head unit is stock, and is likely to stay that way. He thinks the fronts are 6", and the rears are 6x9. I used the best buy tool to try and figure out the size, and it is showing that 6 and 1/2" speakers fit and 6x9" do too. So, I'm assuming he was roughly correct. He has a budget of less than $100 (aim is $60). Can anyone do something good for me? They probably don't need to be powerful since its just a stock head unit. The two fronts are blown. Thanks! Any advice or suggestions would help A LOT! |
Gold Member Username: AdddisorderWest palm, Florida Post Number: 4604 Registered: Jan-06 | phoenix gold octain zr coaxil cheap and efficaint |
Bronze Member Username: ShorterthanrichPost Number: 79 Registered: Apr-06 | This pioneer http://cgi.ebay.com/PAIR-NEW-PIONEER-6-5-440-WATT-3-WAY-CAR-AUDIO-SPEAKERS_W0QQi temZ270126706967QQihZ017QQcategoryZ18799QQcmdZViewItem and this pheonix http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ih=008&sspagename=STRK%3AMEWA%3AIT &viewitem=%26item%3D180109353747%26%26 Those seem to be the best two choices right now I dont know how many watts the stock neon head unit has..so any ideas of what kind of speakers and wattage is optimal? |
Gold Member Username: AdddisorderWest palm, Florida Post Number: 4608 Registered: Jan-06 | its probably around 10rms of of the stock deck. i cant view the PGs but the pioneer are good for what your looking for. |
