Need help with wires in car
Username: Grant24
Post Number: 13
i have a 1997 ford explorer and the 2 wires that come from the car i put on the postive and negtive it makes sound and if i flip them they still make sound if any has come across this problem please help me out
Username: Adddisorder
West palm, Florida
Post Number: 4523
if you can explain better i will help you.
Username: Sheriff
Post Number: 478
What you said makes no sense.
Username: Grant24
Post Number: 14
ok the two wires in the car that ford uses are not red and black. ok if i take the two wires and put them on one way it makes sound and if i switch them they make sound. so my question is what is the diffrence and if it matters.
Username: Matt12490
California USA
Post Number: 2468
So you are saying when you hook up postive wire to positive speaker terminal and negative wire to negative terminal sounds the same as negative wire on positive terminal and positive wire to negative terminal. Right?
Username: Grant24
Post Number: 15
right
West palm, Florida
Post Number: 4529
it will still work but will have the speaker playing backwards and give you a differnet type of sound
