Which options to get 4 bl with only 1000 rms
Username: Garciag
Post Number: 178
im going for the 18 bl and i only have a kx1200 to throw at it so i dont think i will need to many options on it what do you guys recommend or should i just get it with no upgrades
Username: J_baby15
DiRtY 5oUtH ...
Post Number: 1829
a kx1200.1 could be given you around 1400...Kicker makes very good amps and they are usually underrated.
Username: Denim
Www.TeamSSAudio.com, MD
Post Number: 258
Why not ask the Fi guys directly on the Fi forum as to what they feel is the best way to order your BL.
Los Angeles, CA USA
Post Number: 13053
http://www.soundsolutionsaudio.com/forum/index.php?showforum=51
Username: Garciag
Post Number: 179
alright thanks and i was saying around 1000 rms because i have no upgrades and in the manuel it says it puts out 1050 at 12 volts
