Silver Member Username: Killer44Ontario Canada Post Number: 856 Registered: Dec-04 | so im ordering my 2 alphas tmrw and my 1750.1 gunna put them in the bed off my s10 with a cap over them, and they will be comming threw the window, the cab window will be connected to the cap window by way of accordian boot...i stumbled upon this guys cardmain site when i was doing so searching for how to do the cutthrough he has two setups im debating between...main question is which one will sound better and be louder...i prefer the second one where u can see the amp on the back wall...but how it sounds it much more important than how it looks to me...thanks in advance... #1- http://www.cardomain.com/ride/412631/6 #2- http://www.cardomain.com/ride/412631/8 |
Silver Member Username: RenegadesrunLafayette, IN US Post Number: 743 Registered: Oct-04 | My guess. First link is strictly SPL. Sound? Like azz. Louder? Yes. Pic 2? Prolly what you want. It appears to be geared more toward SQ. Sound better? Most likely. As loud? Would be suprised if it was. It takes a bit of work to get SQ out of a L-anything. |
Silver Member Username: Killer44Ontario Canada Post Number: 857 Registered: Dec-04 | no man...i think u got it wrong lol i jsut want to set up my system like that...i got 2 rd alphas....so that said...how would it sound with my stuff lol |
Silver Member Username: RenegadesrunLafayette, IN US Post Number: 745 Registered: Oct-04 | Link 1, loud only. 2... more toward SQ, SQL if you will. I dont care if your using Funky Pups. The sub is irrelevent. Shall i open MSPaint and draw you a picture? |
Silver Member Username: Killer44Ontario Canada Post Number: 858 Registered: Dec-04 | ok so for daily i should go with number 2...i dont need a pic man thats cool...anyone elsee got an opinion on the setup... |
Silver Member Username: Killer44Ontario Canada Post Number: 861 Registered: Dec-04 | bump |
Silver Member Username: KravenbloodOhio DD Z1 you wi... Post Number: 248 Registered: Aug-05 | i dont know which will be louder or what not but i like how the second one is set up just my 2 cents |
Silver Member Username: Killer44Ontario Canada Post Number: 862 Registered: Dec-04 | thanks yeah me too kevin it looks much better imo...but im jsut wondering which one would be the best for a daily setup...im not giong in any comps...jsut want a nice sql setup... |
Gold Member Username: Tremor1127Fi Car Audio has got m... Post Number: 1465 Registered: Aug-06 | i would do 2 for sure... 1 looks horrible no matter how you do it... ![]() |
Silver Member Username: RenegadesrunLafayette, IN US Post Number: 753 Registered: Oct-04 | Drunk and rude. My bad. Still, ...... #2. |
