Silver Member Username: Goodie_goopMidland, Texas U.S. Post Number: 527 Registered: Oct-06 | i gotta a roughly 1^3ft seald box after displacement and i wanna put some pvc pipe to use kinda like aero's to port it since the sub is not worth building another box for...its a 10" and what size piping and how many should i use to get like 32-35 ish tuning? |
Gold Member Username: Nd4spd18Southeast PA Post Number: 1722 Registered: Jul-06 | Ya know that's not gonna work well..... a ported box has to be bigger than a sealed box. And it doesn't matter if the ports are on the outside, it still needs more internal volume. |
Silver Member Username: Goodie_goopMidland, Texas U.S. Post Number: 528 Registered: Oct-06 | eh...that sucks...is 1^3ft ported too small for a 10" |
Gold Member Username: LbecknerTulsa, Ok Usa Post Number: 1495 Registered: Oct-04 | i wouldn't mind knowing either. you can use a box building program to find out.... |
Platinum Member Username: GlasswolfWisteria, Lane USA Post Number: 11977 Registered: Dec-03 | box is too small to port for a 10" you want 1.5cu ft after port and driver displacement. |
Gold Member Username: Extrmndor3IF U HEAR ME... crazydbs.com Post Number: 4566 Registered: Feb-06 | depends if the subs its optimized for mid sized enclousure.... check the speaker recomendations... if its suitable for small ported box it might work but if its more suitable for mid or large enclousure definetely will not work |
Silver Member Username: Goodie_goopMidland, Texas U.S. Post Number: 529 Registered: Oct-06 | its just a sh!tty a-bahn i had from an old system with a sealed box i made a long time ago...how bout if i invert the sub for jus a little more room? jus tryin to make it as loud as possible without too much work ![]() so anyways...i would b better off jus leavin it like it is then? |
Gold Member Username: LbecknerTulsa, Ok Usa Post Number: 1496 Registered: Oct-04 | Hey Glasswolf, what would you say the minimum is for a 12" driver? |
Gold Member Username: Nd4spd18Southeast PA Post Number: 1727 Registered: Jul-06 | You would be best off leaving it as is, unless you want to build a new ported box for it. |
Gold Member Username: OglejustPost Number: 1453 Registered: Aug-06 | for a 12in sub i wouldnt go smaller than 2.0 ported. but some ppl go 1.75 |
Platinum Member Username: RovinMy 1 12 Atom... Post Number: 11329 Registered: Jul-05 | if u really want to use that old box & since its already small , invert the sub & use a external pipe port - will look like sh1t IMO but hey if u wanna try it .....![]() |
Gold Member Username: Extrmndor3IF U HEAR ME... crazydbs.com Post Number: 4593 Registered: Feb-06 | yeah yeah rovin its right... btu it depends th e woofer man.... some woofers can perform better at .70 ported than 1.5 ported |
Silver Member Username: Goodie_goopMidland, Texas U.S. Post Number: 530 Registered: Oct-06 | ya dont care ho wit looks but as long is it sonds better then its cool i guess ima try it...wut do yall think i should fo for lengeth and hom mwanyy?> |
Silver Member Username: Goodie_goopMidland, Texas U.S. Post Number: 532 Registered: Oct-06 | eh...that last post is a little messy i guess i am going to try it and see how it sounds...how do i know how long to make each port and how many i am gonna need |
Silver Member Username: Goodie_goopMidland, Texas U.S. Post Number: 534 Registered: Oct-06 | bump |
Silver Member Username: Goodie_goopMidland, Texas U.S. Post Number: 536 Registered: Oct-06 | bump a site or something? i know some of you use aeros... |
Gold Member Username: CenusHicksville, Ohio Post Number: 3121 Registered: Jan-05 | try it, audioburns allready have shitty sq so it shouldn't sound any worse, i think roe has areo ports or you could talk to marshall white (cannan on here) i think he still sells custom areos. |
Silver Member Username: Goodie_goopMidland, Texas U.S. Post Number: 537 Registered: Oct-06 | ya see i dont really wanna spend any money so i wus jus gunna get some pvc pipe lol...i dont wanna waste money on this sub...but i guess im jus gunna try somethin and see how it sounds lol |
Silver Member Username: JblanfordPost Number: 828 Registered: Oct-06 | goodie are you looking for a site to calculate round port tuning ? www.psp-inc.com |
Silver Member Username: Goodie_goopMidland, Texas U.S. Post Number: 538 Registered: Oct-06 | ahh yes thanks man thats what i was lookin for |
