Silver Member Username: Oglejust15 Inch Wanger Club Pr..., Il Post Number: 711 Registered: Aug-06 | yes the port is broke but i can glue it.![]() ![]() ![]() ![]() |
Silver Member Username: Oglejust15 Inch Wanger Club Pr..., Il Post Number: 712 Registered: Aug-06 | ![]() ![]() |
Silver Member Username: ShortysetniesRock Vegas, NC US Post Number: 926 Registered: Mar-06 | now how strong is that going to be? |
Platinum Member Username: RovinNew sub : 1 ... Post Number: 10465 Registered: Jul-05 | A+ for effort & originality ! gotta ask how u gonna compensate 4 weakening the mdf though - lots of resin & bracing , & that curve - is it worth all that trouble ? ....... ![]() |
Gold Member Username: FrkkevinResonant Engineering..., Fort Worth... Email Post Number: 2754 Registered: Nov-05 | not too bad.. what i meant by cutting the slits close.. was like closer.. 1/4" apart and just where you wanted the bend.. for your first shot ot looks good ![]() too bad it won't fit in your car hehe |
Gold Member Username: FrkkevinResonant Engineering..., Fort Worth... Email Post Number: 2755 Registered: Nov-05 | forgot to mention when you bend it.. before you bend fill all the gaps with wood glue ![]() |
Silver Member Username: Oglejust15 Inch Wanger Club Pr..., Il Post Number: 714 Registered: Aug-06 | lol i no it sux real bad that it dont fit.. takin out my backseats this weekend. ya im puttin resin on it. and no its not worth it lol it was really hard to do. |
Gold Member Username: BestmankindWww.15inchwangers.com Post Number: 9503 Registered: Oct-05 | dude that is bad azz man. great work. |
Silver Member Username: Oglejust15 Inch Wanger Club Pr..., Il Post Number: 715 Registered: Aug-06 | well thanx for teachin me how to do it now lmao |
Gold Member Username: FrkkevinResonant Engineering..., Fort Worth... Email Post Number: 2756 Registered: Nov-05 | what would you do without me ![]() |
Silver Member Username: Oglejust15 Inch Wanger Club Pr..., Il Post Number: 716 Registered: Aug-06 | lol um not have a flared slot ported box? |
Gold Member Username: FrkkevinResonant Engineering..., Fort Worth... Email Post Number: 2758 Registered: Nov-05 | i guess ya got me there ![]() if you trace that curve and cut a piece to fit into the bend then glue it in.. itll support the bend plenty after you glue the slits brace would look something like a " D " |
Silver Member Username: Oglejust15 Inch Wanger Club Pr..., Il Post Number: 717 Registered: Aug-06 | ya i thought about that but idk if i will or not.. im kinda lazy |
Gold Member Username: Tdeaton1021Near Tampa, Florida USA Post Number: 3540 Registered: Sep-04 | looks good. you always have to mess up the first time, thats how you get to where you wanna be. one day you'll be doing stuff like that with your eyes closed lol. |
Silver Member Username: Goodie_goopMidland, Texas U.S. Post Number: 146 Registered: Oct-06 | that looks tight |
Gold Member Username: FrkkevinResonant Engineering..., Fort Worth... Email Post Number: 2759 Registered: Nov-05 | np for teaching ya btw.. ill answer any question i can if asked i'd do a flared slot too.. but i can't on my next design ![]() |
Silver Member Username: Oglejust15 Inch Wanger Club Pr..., Il Post Number: 718 Registered: Aug-06 | ya i have to thank kevin for the idea and help and i have to thank canaan for the design. ![]() |
Gold Member Username: Extrmndor3Sit and Look pretty Post Number: 3264 Registered: Feb-06 | so your telling me that if i get a regular mdf thing i just cut lil lines like he did and it will bend??? |
Gold Member Username: Mr_keboAlbertville, Al USA Post Number: 1176 Registered: Nov-04 | yep, ive actually done it before on a box, i will try to find some pics. |
Silver Member Username: Oglejust15 Inch Wanger Club Pr..., Il Post Number: 719 Registered: Aug-06 | ha.. its harder than that... took a lot of practice to get the depth right and the spacing right. |
Gold Member Username: Mr_keboAlbertville, Al USA Post Number: 1177 Registered: Nov-04 | nah not really lol. its pretty straight foward, bend slow and fill will glue as said above. |
Silver Member Username: Oglejust15 Inch Wanger Club Pr..., Il Post Number: 720 Registered: Aug-06 | well it was hard 4 me so.. im just sayin on my test pieces they kept breaking... you just have to work with it for a while. |
Gold Member Username: BestmankindWww.15inchwangers.com Post Number: 9505 Registered: Oct-05 | make sure you throw down some resin mat before you resin it. |
Gold Member Username: RvlacosDD 3512 United States Post Number: 1346 Registered: Sep-06 | looks like a tcab box! |
Gold Member Username: Mr_keboAlbertville, Al USA Post Number: 1178 Registered: Nov-04 | yea, its the same tecknique they use. Def lay some resin matt down first. |
Gold Member Username: Matt12490The biggity biggity BAY, California USA Post Number: 1534 Registered: May-05 | how do you cut it that deep without goin through? |
Silver Member Username: JblanfordPost Number: 325 Registered: Oct-06 | lower the blade on the table saw...lol |
Gold Member Username: Mr_keboAlbertville, Al USA Post Number: 1179 Registered: Nov-04 | hahaha |
Silver Member Username: Andrew571Stillwater/Edmond, Oklahoma USA Post Number: 594 Registered: Oct-05 | that is so sweet looking |
Gold Member Username: Matt12490The biggity biggity BAY, California USA Post Number: 1535 Registered: May-05 | sorry i dont use a table saw thats why i wouldnt know |
Bronze Member Username: WarlokOrlando, FL USA Post Number: 61 Registered: Dec-05 | F-N A That bad a** ! Nice idea. Well, if I ever make one like that, I'll make mention of your name. A++ An asset to E-coutics (LoL) |
Gold Member Username: FrkkevinResonant Engineering..., Fort Worth... Email Post Number: 2760 Registered: Nov-05 | you can lower the guide on a circular saw as well ![]() |
Silver Member Username: Oglejust15 Inch Wanger Club Pr..., Il Post Number: 721 Registered: Aug-06 | do i have to put mat down? i was just gonna pour resin in it. btw.. got it glued down all thats left is the resin. ![]() |
Bronze Member Username: Derick06Rio Grande City, Texas United States Post Number: 58 Registered: Nov-05 | here's a nice little tutoring site on how to do it: http://www.teamtoxicbass.com/literature/tutorials/index.htm Just click on the first one that says wood bending and it tells you how to do it. |
Gold Member Username: B101DD, RE, FI, TREO, KICKERUSA Post Number: 4138 Registered: Sep-05 | yea, that box looks great, let us know how it sounds.. |
Silver Member Username: Oglejust15 Inch Wanger Club Pr..., Il Post Number: 722 Registered: Aug-06 | ok i took my back seats out today.. it made it way louder. especially when i do outlaw. but i was wondering what if i seal off my trunk.. would it b louder than if it was outlaw? i just want it loud w/o having to pop my trunk. |
