just got the tripple x and my amp instaled in my car i ended up running the power underneath the car through the chassis then drilling up underneath the back seat then running it through a hole i found leading into the trunk still have to mount my amp better it keeps coming unpluged from the power but nothing rattles inside the car the fenders around the trunk have like an inch of flex i wish i had a camera that could take videos its a must see ill get pics later maybe. thanks for all the ideas guys
its actually sealed the last car i had it in that was all i could do literally had like no trunk left and had to remove the trunk latch and some trim and what not just to get it in and push like hell so this on almost stands up im gona make a new box though ported and resigned then im gona make it wider and shorter so it can stand
monster sub just falls right in i dont have to move anything i still have a full size spare in there and can fit 2 more people with the sub and amp in there
QUARTER PANNELS are on the bottom this would be called rear fenders if they were truely quarter pannels why would this make sense....... REAR FIBERGLASS FENDERS
JC Whitney Price: $439.99 - $449.99
Review this product Financing Available: This Product Qualifies for Deferred Payment! View Details
Rustproof and shock resistant Perfect with dual wheel adapters No costly body work--just trim and bolt on. Ready-to-paint gelcoat finish. Installs with regular hand tools. Instructions included. Additional fender extension required depending on application. Some trimming and modification/extension of gas filler tube may be required. Shipped separately from factory. NOTE: SKU numbers ending in F are factory shipped and may take a little longer to reach you. taken from jcwhittney.com
