New member Username: Baysideftb91Post Number: 1 Registered: Nov-06 | I was looking at the Kicker 6 1/2" Speakers (KS6.2) and the Polk 6-1/2" Component Speakers (db6500) which one do you all recommend and is there others that i should be concidering? The highest I can go price wise is probly about 250 maybe a little higher. thanks |
Silver Member Username: JohammbassIRL Post Number: 707 Registered: May-06 | http://cgi.ebay.com/DLS-UP6-6-5-2-WAY-COMPONENT-SPEAKERS-ULTIMATE-NEW-UP-6_W0QQi temZ250054642168QQihZ015QQcategoryZ32819QQssPageNameZWDVWQQrdZ1QQcmdZViewItem http://cgi.ebay.com/NEW-DLS-ULTIMATE-UR5S-2-Way-Component-System-5-1-4_W0QQitemZ 190053858742QQihZ009QQcategoryZ32819QQssPageNameZWDVWQQrdZ1QQcmdZViewItem http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=5091 All of the above would be better than the stuff that you listed ![]() |
Gold Member Username: AlteraudiousaConcord Post Number: 1350 Registered: Jan-06 | i would get the HD-62 over the ES as the ES is going to be replaced and the HD has better frequency response over the ES. I do like the ES smooth high midrange though. |
