Bronze Member Username: DlocWHITTIER, CA USA Post Number: 73 Registered: Jul-06 | wat is the same as dynamat but not as expenxive as dynamat....if there is were could i get seuff to make my bass sound better |
Silver Member Username: KenwaPost Number: 405 Registered: May-04 | I have seen stuff on ebay, check there. |
Bronze Member Username: DlocWHITTIER, CA USA Post Number: 75 Registered: Jul-06 | wasnt thinking to order do they sell it like at hardware stores??? |
Silver Member Username: KenwaPost Number: 407 Registered: May-04 | Im not sure how it works but a few guys on this forum were talking about stuff called peel and seal. You can buy it at lowes and somewhere else. Search the forum for peel and seal and you should be able to find that thread, it should answer your questions. |
Gold Member Username: Basshead86Try Google Post Number: 7429 Registered: Aug-05 | http://www.sounddeadenershowdown.com/ |
Silver Member Username: Th3pwn3rChicago, Illinois U.S.A Post Number: 685 Registered: Jul-06 | If you want to save some money go with the ED sound deadener,I would go with Vse1squared or you can go with FatMat.I would take either of those two over Dynamt. |
Gold Member Username: BestmankindWASSUPUSA Post Number: 6390 Registered: Oct-05 | home depot has some asphalt based stuff. it works great i hear. only downside is the asphalt smell. |
Gold Member Username: RedlinerWilmington, Ma Post Number: 2763 Registered: Jun-05 | ya when it gets hot outside chad nd t heats up but if u live in antartica it is fine lol |
