is it better to have them facing twards that back or to the front. i have my back seat down so it is louder but was wondering if i face them twards me then they would be louder.
also i was wonder if anyone knew a good site to build boxes cuz im getting new subs and need a new box.
well.. if you have the sub/port facing into the cabin towards you it will be louder.. your placing yourself closer to the port.
if it faces towards the trunk it will sound better.. your not really going o heard that much of an audible difference.
something to consider is if the sub/port face the trunk you will in most cases have more issues with trunk rattles. of course every vehicle is different so the best thing for you is to try both ways and see whih ones works better for you .. its your ear so whatever sounds best to you is the way you need to go
