New member Username: DabigpapaPost Number: 7 Registered: Sep-06 | Im new to subs & amps but how many amp watts per sub watts are needed for the amp to handle the sub for example a sub with 3,000 Watts Nominal Power how powerful does the amp need to be & how many do i need. Thanks. |
Silver Member Username: Th3pwn3rChicago, Illinois U.S.A Post Number: 270 Registered: Jul-06 | Well just pay close attention to the RMS rating.Then match your sub with an amp that comes close to that.Beware though as some amps are over-rated and some are under-rated,over-rated amps will claim 1600 watts RMS and they actually put out only 1500 or something like that,as to under-rated amps will put out more than what they claim.Also pay attention to ohms. |
Silver Member Username: Tremor1127Post Number: 208 Registered: Aug-06 | true robert, but depending on what your looking at there could be a way larger margin of over or under rating... http://www.crutchfieldadvisor.com/S-QhW5Qrhd9z7/reviews/amplifiers/20050712/rock ford_punch45.html?page=3 ^^^ that rockford fosgate amp is rated at 22.5 watts rms X 2 channels and put out 79 rms X 2 with a max power of 753 watts i think... almost 3 times the power... there are probably more overrated amps out there though... ![]() |
Silver Member Username: Tremor1127Post Number: 209 Registered: Aug-06 | and that amp is way expensive for a 45 watt amp... |
Gold Member Username: Dustin3Tigard, OR U.S. Post Number: 3592 Registered: Oct-05 | well it does around 300 watts @ 2 i believe. |
Silver Member Username: Tremor1127Post Number: 211 Registered: Aug-06 | i know, almost 3 times the rated power at @ 2ohms, i didnt type that because it was obvious... |
