Silver Member Username: Ishkabobble55Erie, Pennsylvania Post Number: 316 Registered: Jul-05 | so ive decided to start a project, i am going for sql. how do these plans look? http://www.subwoofertools.com/forum/ported-box.asp?Ew=38&Eh=14&Dia=6&Xmax=12&Vd= .13&NumW=2&Vb=3&Fb=30&Qts=&Vas=&Fs=&CE=0 |
Gold Member Username: RovinTrinidad & T... Post Number: 8948 Registered: Jul-05 | which model ? RE SE SX ? if its the RE RE model then ya that looks good on paper ..... |
Gold Member Username: SouthernrebelMonroe, Louisiana USA Post Number: 3202 Registered: Mar-04 | yea...if they are RE re's, that would be a good bx for SQ. I would tune to ~35hz if you want a lil more SPL (SQL). |
Silver Member Username: Ishkabobble55Erie, Pennsylvania Post Number: 317 Registered: Jul-05 | ya the RE re's, will i be able to tell a huge difference in sq if i port it at 35hz rather than 30? im sorta done with alot of spl, its fun for a short time, but then it gets annoying. still it would be nice to have it get loud once and awhile. what about 32hz, thats what re recommends |
Gold Member Username: SouthernrebelMonroe, Louisiana USA Post Number: 3203 Registered: Mar-04 | 32hz would be great. |
Silver Member Username: Ishkabobble55Erie, Pennsylvania Post Number: 318 Registered: Jul-05 | ive been thinking, i might actually sell my 2 12"s and buy 4-8" assassins and port those. i need to find a different enclosure program though, the one i used only goes up to 3 woofers. how do you think the assassins will compare? does anybody know of a different program? |
Silver Member Username: Ishkabobble55Erie, Pennsylvania Post Number: 319 Registered: Jul-05 | BUMP |
Silver Member Username: FrkkevinLake Worth, Texas US Post Number: 499 Registered: Nov-05 | Bass Box Pro 6.. or you could make it for two for half the size of the box and just duplicate it for the other half ![]() |
Silver Member Username: Ishkabobble55Erie, Pennsylvania Post Number: 320 Registered: Jul-05 | ya but dosnt that change the ports tuning? |
