Gold Member Username: BlainewPost Number: 1291 Registered: Nov-05 | what guage wire for an orion 2500d?? |
Silver Member Username: LoudonPost Number: 381 Registered: Jun-04 | zero |
Gold Member Username: RovinTrinidad & T... Post Number: 8310 Registered: Jul-05 | i have that amp actually it has 2 seperate power supplies & 2+ /2- terminals which only up to 4g will fit so i suggests u get a 0g into 2) 4g distro block ...... |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 1039 Registered: Dec-05 | www.bcae1.com hit wires for future setups |
Gold Member Username: BlainewPost Number: 1292 Registered: Nov-05 | rovin, where do i put the distro block by the amp or by the batt?? |
Gold Member Username: BlainewPost Number: 1293 Registered: Nov-05 | and to add to that....when the 0 guage splits to 4, do i need an inline fuse in each 4 g wire, and an inline in the 0 g wire |
Silver Member Username: Scott_debakerPittsburgh, P.A. U.S.A. Post Number: 584 Registered: Feb-06 | |
Gold Member Username: BlainewPost Number: 1294 Registered: Nov-05 | scott ... do you have 0 guage going to 4 guage? |
Silver Member Username: Scott_debakerPittsburgh, P.A. U.S.A. Post Number: 597 Registered: Feb-06 | noperz all 0/1 |
Gold Member Username: BlainewPost Number: 1295 Registered: Nov-05 | alright thanks and one more question... how many amps is your alternator |
Silver Member Username: Scott_debakerPittsburgh, P.A. U.S.A. Post Number: 599 Registered: Feb-06 | right now its stock only usin 1700W @ 2ohms but my car iam gettin a 200amp ho alt but dont use 0/1 4 the amp part use 0/1 from battery an use 4g from dist. blocks cause its a bi1ch 2 get the 0/1 in there or if u can find sum bananna plugs make it from 0/1 to 4g |
Gold Member Username: BlainewPost Number: 1296 Registered: Nov-05 | alright thanks alot |
Gold Member Username: RovinTrinidad & T... Post Number: 8311 Registered: Jul-05 | that amp only accepts 4g power/ground cable - its even in the manual which i have right here put distro block near ur amp as possible i suggest when u begin running ur 0g put 1 200A fuse (thats how much i guestimate it pulls -there r formula online 2 check it though) put this 1st main fuse about 12" away from + terminal , well the distro block will have 2 holders for 2 fuses so each fuse will be 1/2 of main fuse . This amp pulls serious current so i strongly suggest a HO alt & @ least 1 drycell batt.... |
Gold Member Username: BlainewPost Number: 1297 Registered: Nov-05 | ok thanks |
New member Username: JtmartinusPost Number: 1 Registered: Jul-06 | I NEED HELP FOR BIN FOR VIEWSAT |
Gold Member Username: BlainewPost Number: 1299 Registered: Nov-05 | what? |
