Silver Member Username: Gangstafert
Jacksonville,
Florida
Post Number: 175 Registered: May-06
Posted on I could not get help anywhere else but i was wondering whats a good car security system for around 350$? |
Silver Member Username: Ctmike
Ct.
Post Number: 870 Registered: Feb-06
Posted on try clifford brand, i think there base model is around that price and includes the remote pager thats goes off with your car alarm. |
Gold Member Username: B101
Queen City,
NC
Post Number: 3394 Registered: Sep-05
Posted on for that price, u can find a VIPER on ebay... NEW with Warranty.... Autopage are some cheaper decent ones.... most should be standard with remote start now...  |
Jacksonville,
Florida
Post Number: 176 Registered: May-06
Posted on does standard mean 2way pager thing so that it tells you if your alarm is going off, and what is remote start? |
Silver Member Username: Camaro823
British Colu...
Post Number: 386 Registered: Jun-05
Posted on yes that does tell you when your alarm is going off, remote start allows you to start your car with the push of a button on the remote I believe |
