Plexiglass substitution
Username: Drivingreckless
Near tampa, Florida United state...
Post Number: 435
i want to make the top portion of my box plexiglass is this a good idea??? i can get 3/4 thick plexiglass...reccomended????will this affect the sound???
Post Number: 436
bump bump bump bump
Username: Matt12490
Benicia, California USA
Post Number: 874
i think it will be fine. i heard the minimum should be 1/2" so 3/4" should be fine. as far as sound quality i think it wont be affected as long as there are no air leaks. im not sure what you are supposed to glue it with like all wood boxes. that would be another question. make sure you predrill every hole with plexiglass!
Username: Matt12490
Post Number: 875
didnt bump^
Username: Alex_f
Lawrenceburg, Ky Us
Post Number: 827
You would be crazy to use 3/4 inch plexiglass, because it is crazy expensive. 1/8 works fine.
Username: Redliner
Wilmington, Ma
Post Number: 1894
just remember plexi is really expensive measure 3 cut once
Post Number: 440
my frins dad sales it so i can get it cheap :-O also u sed glue or drill???? or both????
Username: Matt12490
Post Number: 877
first off dont listen to that guy. 1/8" is just stupid. i didnt say to glue it, i was saying i dont know what to use around the edges. i would deffenetly screw it down tho.
Username: Alex_f
Lawrenceburg, Ky Us
Post Number: 829
well, it is easy to crack. If its a smaller peice, you want 3/4inch mounting area all around. if its bigger do 1inch. And use a drill bit first.
Post Number: 441
oh okay-basically treat it as wood seal it glue it and drill it
Username: Redliner
Wilmington, Ma
Post Number: 1898
use a small drill then go bigger take your time dont rush it then i would put some clear glue on it and screw it down but thats just me im sure you could get away with just screwing it though but it wouldnt be sealed as weell as it would if you use glue
Username: Matt12490
Post Number: 883
i think you deffenetly need some kind of glue
Post Number: 442
right i probably will seal it with silicone and use sum kind of clear adhesive.but yes i get wut ur sayin take my time and make it look nice....im only making one side plexiglass so i can show off the magnet...also stick sum blue or green neons in the box and make tth sh!t pleasing to the eye at nite....
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 1206
you could use 3/4 inch plexi and it would be fine.. i would do a double layer of mdf wherever it is going so you can inset the plexi so it is flush with the wood.. use a countersink bit on the plexi and screw it into the mdf.. use clear silicone where the plexi contacts the wood.. maybe even let it set up a little bit before you screw it down.. the silicone will act as a airtight sealUpload
Username: Rzarector
Post Number: 1208
Post Number: 449
tht is actually a very good idea i wuz thinking of makin the whole side clear but i see u have a better idea thnx mark s
Username: Extrmndor3
Chicago, Ill Us
Post Number: 748
hey make a plexi box for this sub
Chicago, Ill Us
Post Number: 749
Username: Matt12490
Post Number: 886
ok...?
Username: 54danny54
Betsy layne, Kentucky..GO... USA duh
Post Number: 2421
that magnet looks so friggan small on that 18 lol
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 7085
It really does.lol
Chicago, Ill Us
Post Number: 756
yeah but it slams 145 wit 1500 rms and a box tuned to 25hz
Post Number: 450
lil rob is tht the only pisture u have LMAO:-O
ive seen it on like 3 other threads LMAO
Post Number: 7086
I dont think it hits, 145 with a box tuned that low, thats impossible
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 2977
i think he meant 35hz.
Chicago, Ill Us
Post Number: 759
yeah my bad yeah 35
Chicago, Ill Us
Post Number: 760
ford explorer wit a dcx precicion power 1500.1 well i gave this amp to my cousin so im lookin ofr another amp that can push more my sx than the precicionpower
Chicago, Ill Us
Post Number: 761
Chicago, Ill Us
Post Number: 766
hey havoc have u ever saw a magnet of a 18 inch avalanche???
if so u will now for a 18 inch this sx is good enough
Chicago, Ill Us
Post Number: 767
i know the size of the magnet do not meant nothing is how powerfull they are
Username: B101
Queen City, NC USA
Post Number: 2858
way to HIJACK a thread... start ya own next time... LOL
Post Number: 2982
lilrob. the avalanche had a 9 inch wide magnet. thats larger than the sx magnet by a long shot im pretty sure. and why do you post it EVERYWHERE? i think your inlove with it? did you lube up the hole in the backplate? haha im sorry, couldnt resist.... but you are obsessed with that picture.... its not a boombox, take it off your shoulder and put it back into your car.
Post Number: 2983
btw. id use the thickest plexi you can afford. or lexan. check ebay. sometimes they have like 1 inch by 12x24 for like 20 bucks because its got a chipped corner which you'd cut off anyways.
Chicago, Ill Us
Post Number: 775
yeah bro i see u got jokes hahha yeah the avalanche has 9 inch wide but i was talkin about the looks in lokks frikin small too and the size do not matter is the bl or power, btw is already in my car well not cuz i dont have an amp right now
Post Number: 2988
i think its the shocker sig, those 18s have such a huge magnet it doesnt look small one bit lol. somewhere there is a picture of them being used as a coffee table. its bada55
