Silver Member Username: ReloadedMebane, NC U.S.A Post Number: 142 Registered: Dec-05 | A MBQuart RAA1000 AMP http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14965 on two (2)12" AA Assasins? or would it be good what would you reccomend. An amp at the same price or lesser. |
Silver Member Username: ReloadedMebane, NC U.S.A Post Number: 143 Registered: Dec-05 | dang whats up with that, I said whats this be too much LOL dang , juss a lil too sleepy |
Silver Member Username: CtmikeCt. Post Number: 270 Registered: Feb-06 | i'd say it's good to go. i've heard good things of this amp, i think rovin uses one for his type r's. i've been told the aa subs can handle a little more then the rms so you should be set with this amp. |
Silver Member Username: ReloadedMebane, NC U.S.A Post Number: 144 Registered: Dec-05 | should I get the service plan or not worry about it? How long will it take to get to me too? |
Gold Member Username: RovinTrinidad & T... Post Number: 7363 Registered: Jul-05 | GR8 amp - but NOT 4 his application assasins r 4 ohms SINGLE COIL 2 4ohms SVC subs = a 2ohms load ![]() that amp does 500wrms @ 2ohms so it will underpower - u need a 700wrms @ 2ohms amp like alpine MRD-M1005 RMS Power (at 12V,20Hz-200Hz) * Per channel into 2 ohms : 700W x 1 * Per channel into 4 ohms : 500W x 1 RMS Power (at 14.4V,20Hz-200Hz) * Per channel into 2 ohms : 1000W x 1 (1% THD) |
Silver Member Username: CtmikeCt. Post Number: 272 Registered: Feb-06 | didn't bother checking the vc config on the sub, thought they were dual vc. good catch. |
Silver Member Username: Matt12490Benicia, California USA Post Number: 708 Registered: May-05 | lol i thought right from the begining of this thread that its only going to be 250w per sub, then i kept scrolling down and saw rovin was on it. |
