i have a 12 inch ma audio synergy sub its in a slot ported box running off a kicker kx 1200.1 at 1 ohm.my sub heats up real fast and im worried it will overheat and break.anything i can do?
mine did that to im 95% sure it was because the box was way to small and I was playin them loud I suggest you get the right size box for your subs if you have not yet!!!!
