New member Username: BumpthatPost Number: 1 Registered: Mar-06 | I need some opinions on this set up i am thinking about getting. 2 10" Alpine SWR-1042D -power handling: 200-500 watts RMS -peak power: 1,500 watts Kenwood KAC-9152D 1800w Class-D Mono Amp -Max Power: 1800 watts -RMS 500 watts (4 Ohms, Less than 1% THD+N) -Rms 900 watts (2 Ohms, Less than 1% THD+N) -RMS 900 watts (1 Ohm, 100Hz, 1% THD at 14.4V) I plan on running them parallel at 2 ohms. What do you think? Also Ported or Sealed box? I am leaning more towards ported. Thanks |
Silver Member Username: Dustin3Tigard, Or U.S. Post Number: 696 Registered: Oct-05 | for type-r's def. go ported, you get the full potential of the subs... sounds good... |
Silver Member Username: CtmikeCt. Post Number: 156 Registered: Feb-06 | get a bigger amp. i have the 12" type r's and trust me, they can handle more. try to get an amp that will give them each about 550-650wrms. |
New member Username: BumpthatPost Number: 2 Registered: Mar-06 | ok i will look around. but if i cant find anything in my price range will i be ok with the amp i listed? also how would i wire the 2 10's parallel (2 ohms) if they are dual voice coil (4 ohms each) ? |
Gold Member Username: CenusHicksville, Ohio Usa Post Number: 1552 Registered: Jan-05 | 2 dvc4ohm subs can only be wired to 1ohm or 4ohm. and whats your price range for a amp, im sure some1 on here can find something better. |
New member Username: BumpthatPost Number: 3 Registered: Mar-06 | damn only 1 or 4homs? that sucks price range: $200-$300 |
Gold Member Username: James1115Ct Post Number: 5473 Registered: Dec-04 | http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D9703890833%26&sspagename= STRK%3AMESE%3AIT%26 that does 800 watts at 1 ohm at 12 volts more like 900 at 13.8 volts. The only thing you would need is to switch the fuses from 30's to 40's and your all good![]() |
