Got Ripped Off
Username: Shredmaster1013
Post Number: 28
Just payed $160 for 2 sets (4 apeakers) of kole 6x8" kps-683 180W 50Hz-20Khz speakers .. then it was $80 for them to get installed.. This was done at Shockwave Customs in illinois.. they are a Cadence dealer.. I just found a site with the same speakers for 24.13 http://electrogalaxy.dtopinc.com/index.html?object=kolkps683 and one for 33.58 http://www.shop.com/op/~KOLE_KPS_683_KPS_SERIES_SPEAKERS_6_Inch_X_8_Inch_KPS_683 -prod-27583601-36426795?sourceid=298 Do you think they will give me a refund..?
Username: Alteraudiousa
Concord
Post Number: 393
probably not unless those sites are an authorized dealer and Kole audio......hmmmm there is much better out there.
Username: Tjmutlow
Post Number: 1607
well, seeing how they are basically a power acoustik piece........
