Bronze Member Username: Jarryd2018Post Number: 85 Registered: Sep-04 | Ive been looking at getting 2 12" type R subs but im wondering if theres anything else i can get that might be better for the money. i want something that can be really loud when i want to show off but sound really good when i just want to enjoy my music. i can get the type Rs for about 115 apiece. is there anything else that might be better for the money? |
Bronze Member Username: Goose5714Post Number: 82 Registered: Feb-06 | Maybe 2 re se's or some l7's for straight spl... |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 1624 Registered: Dec-05 | he said he wants something that sounds really goood..dont get the l7's |
Bronze Member Username: Jarryd2018Post Number: 86 Registered: Sep-04 | any other options? i dont know anything about the RE SEs. im sure they have good quality because they are from RE but will they get as loud as the type Rs? |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 1662 Registered: Dec-05 | yeah they're supposed to get a little louder than the r's |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 5618 Registered: Jul-05 | Re se Kicker cvr CW V-Max's Type R's Ed v.2's Jl w6v2 Crystal Comps |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 5619 Registered: Jul-05 | my bad didnt see the budget CVR's, SE's, or R's Personally i would go with the se's but thats just me. |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 1663 Registered: Dec-05 | chauncey which gets louder .. a r , se , or rlp ? and which will sound best |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 5630 Registered: Jul-05 | the r-lp would get louder, and also i would give it a slight nod in sq as well |
Silver Member Username: Biggyg9712Post Number: 228 Registered: Sep-05 | whats the r-lp, and who makes it |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 5631 Registered: Jul-05 | http://soundsplinter.com/rlp_premium_series_12_and_15_inch_subwoofer.html |
Bronze Member Username: Jarryd2018Post Number: 87 Registered: Sep-04 | where can i get the RE SE subs at? |
Gold Member Username: TdbdadrummerWellsburg, WV USA Post Number: 1290 Registered: Aug-05 | I'd take the Assassins over the Type-R any day. Or the SE works very well too. You really can't compare brands like RE and AA to Alpine in quality and power handling. Just by looking at the build quality strictly of the woofers you can tell they don't even compare. |
Silver Member Username: JronPost Number: 141 Registered: Jul-05 | yeah I would steer clear of the Alpine, not a bad sub but better can be had for the price. |
Bronze Member Username: Greeney1888Maple Grove, MN United States Post Number: 70 Registered: Feb-06 | you can get RE subs at www.reaudio.com and to order: (702) 896 4823 |
Bronze Member Username: Jarryd2018Post Number: 88 Registered: Sep-04 | well like i said, i can get the type Rs for 110 a piece for the 12s. is there anything better for that price? |
Bronze Member Username: Jarryd2018Post Number: 89 Registered: Sep-04 | I might have found a deal on some SEs. will the be noticably louder than the type Rs? |
Silver Member Username: JronPost Number: 144 Registered: Jul-05 | no matter how you look at it, the type r's are comparable to the Re Se's. upgrade to a better 12 like an eclipse ti, treo ssi, id max or something along those lines man, it's about 100 more, and you are saving trunk space. ![]() |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 5652 Registered: Jul-05 | "no matter how you look at it, the type r's are comparable to the Re Se's." Not really, maybe in spl, but not close in quality or sq |
Bronze Member Username: Jarryd2018Post Number: 90 Registered: Sep-04 | if i can get these SEs for a decent price, Ill get them. what would be a good amp to match up to them? |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 5654 Registered: Jul-05 | 1200-1500 rms @ 1 ohm how much can u spend |
Silver Member Username: JronPost Number: 146 Registered: Jul-05 | not really a huge difference in either sq or spl to me. But a well built enclosure has a lot to do with it. |
Bronze Member Username: Jarryd2018Post Number: 91 Registered: Sep-04 | i can probably spend about 200 on an amp. ill get one off ebay most likely. what would be a good one to look for to power them? |
