Bronze Member Username: MiriamrowlandFt. drum, New york Us Post Number: 20 Registered: Jan-06 | whats better a jl w7 or alpine type x????? |
Silver Member Username: SpyderEglin AFB, Florida USA Post Number: 257 Registered: Jun-05 | both are good but the w7 is just not in the same league in my mind...the type x gets loud.......sounds decent doing it aswell.....but the w7 is just one of those things that you can't compair it to.....to compair a W7 you need to thing RE XXX, Idmax or Eclipse |
Silver Member Username: Southern_bassParis, Tennessee U.S. Post Number: 727 Registered: Dec-05 | thats like comparing a pacer to an escalade lol.....nah its not that bad just always felt like making that comparision ![]() |
Gold Member Username: Mikechec9Http://www.cardomain.c... Post Number: 1983 Registered: May-05 | this is pretty funny to me. alpine has had a glossy 6month install car at ces for the past few years. jl enters their chief engineer's stock subaru with stealth install. right off the bat, the two companies are unintentional rivals in the field. impractical, glossy show car vs clean and respectable daily driver. |
Gold Member Username: Mikechec9Http://www.cardomain.c... Post Number: 1986 Registered: May-05 | http://mobile.jlaudio.com/jlaudio_pages.php?page_id=191 http://mobile.jlaudio.com/pdfs/DailyDriver_2006.pdf |
Silver Member Username: Lil_jonPost Number: 281 Registered: Jul-05 | i like that w7 13 for some reason it sounds like a 15 |
Silver Member Username: UcfsaxmanOviedo/orlando, Fl Post Number: 517 Registered: May-05 | b/c it was designed to sound like a 15 w/ exceptional SQ. |
Bronze Member Username: Johnny619San Diego, CA Post Number: 15 Registered: Dec-05 | I got a 12w7 and it is great, JL Audio should stick with making sub and amp as for Alpine they should stick with making Headunit. |
Silver Member Username: Southern_bassParis, Tennessee U.S. Post Number: 740 Registered: Dec-05 | what amp ya got johnny ? |
Gold Member Username: Jonathan_fGA USA Post Number: 5414 Registered: May-04 | "I got a 12w7 and it is great, JL Audio should stick with making sub and amp as for Alpine they should stick with making Headunit." JLs components are great, too. Don't know why they should stick with just subs and amps, you should go listen to the ZRs. Really nice set. Alpine, I agree with you. Only speakers of theirs worth having are the Type-X and the F#1 Status speakers, but Genesis Audios version of the Revelators are much better. |
Gold Member Username: Jonathan_fGA USA Post Number: 5416 Registered: May-04 | "this is pretty funny to me. alpine has had a glossy 6month install car at ces for the past few years. jl enters their chief engineer's stock subaru with stealth install. right off the bat, the two companies are unintentional rivals in the field. impractical, glossy show car vs clean and respectable daily driver" I'll take clean, respectable daily driver personally. I get tired of seeing all this bling bling uber-riced crap, fiberglass is only good when used in moderation |
