Silver Member Username: BlainewPost Number: 115 Registered: Nov-05 | if u have2 dual 4 ohm voice coil subs u must wire them individualy in series or parallel before u can connect them to a mono amp..then once each sub is wired in series or pralel..u have to wire them together in series or paralel... if u have 2 dual 4 ohm voice coil subs can u wire each individual sub in series..and then wire them both in paralel to connect them..to the amp..or if u wire individual subs in series do u have to wire them together..connect them together in series |
Gold Member Username: RovinTrinidad & T... Post Number: 3143 Registered: Jul-05 | http://www.the12volt.com/caraudio/woofer_configurations.asp |
Silver Member Username: MixneffectOrangevale, Ca. USA Post Number: 610 Registered: Apr-05 | ![]() ![]() ![]() ![]() |
