Dog hair, dust bunnies, etc.
Username: Dpaw20
FL USA
Post Number: 295
Say I were to stoe my subs in my room's closet for say, a few months.
Would the possible build up of maybe dog hair and dust hurt it in any way?
Do you strongly suggest putting them in a box or wrapping first?
Username: Tdisanto
Post Number: 38
Depends on the materials the sub is made of. Foam surrounds are subject to decay, prolly not from cat hair though. I would imagine moisture (excessive humidity and such) would be the biggest threat to the surrounds (if foam) and the cone if its made out of a poorly treated paper.
Best thing to do would be too wrap the sub anyways. Its not gunna hurt. better safe than sorry anyways, right.
Username: Basshead86
Ocala, FL USA
Post Number: 1242
haha, acid dog hair, and fanged dust bunnies.
just put it in something with a lid on it and forget about it.:-O
Username: Mixneffect
Orangevale, Ca. USA
Post Number: 360
I stored a couple of Vifa soft dome tweeters in a hallway closet for a while (1-2 years). A lot of dust has colected on the diaphragm and perhaps in the voice coil as well. I have played them just recently, just to see if they still work. The answer is yes, but they werent as crisp as a new set.
You ar ewondering about subs, so this is a lil different. The subs may have a vented pole peice, or dust may get in through the spider, who knows.
If you boxed them and then wrapped plastic on them, it may improve clenliness and may preserve them. Always store the woofers with the cone firing sideways, that way the suspension doesnt get weaker.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10383
just wrap em in a layer of bubble wrap to protect them
use some compressed air to blow out the dust before the next use.
easy
Username: Dpaw20
FL USA
Post Number: 296
ty for the replies
never knew about storing them sideways, ty.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10425
I store mine in pairs, face to face and zip-tied together.
Username: Tdisanto
Post Number: 60
good call on the sideways storage technique mixneffect, i bet over a years or too that good weakin the suspension.
Username: Tdisanto
Post Number: 61
could weakin
sorry brains fried, classes suck
