99quesitons. Unregistered guest | Does http://www.knukonceptz.com/productMaster.cfm?Category=Installation%20Accessories # stuf flike that make a difference?? |
99 Questions. Unregistered guest | Gold Plated Crimp 1/0 Ring Terminal - Black Grommet. Ring opening is 5/16" is what im reffering to by the way. |
99Questions. Unregistered guest | awell as Gold Plated 10 Gauge Spade Terminal - Black |
Gold Member Username: CarguyPost Number: 4230 Registered: Nov-04 | If you're asking about conductivity, then yes. Gold plated gives better current flow and contact. |
99questions Unregistered guest | and better conductivity improves..... |
Silver Member Username: Basshead86Ocala, FL USA Post Number: 950 Registered: Aug-05 | a cleaner, stronger signal transfer between amp wires and speaker wires. you won't have as clean or strong of a signal if you had stainless steel speaker terminals as opposed to gold ones![]() |
Gold Member Username: GlasswolfWisteria, Lane USA Post Number: 9959 Registered: Dec-03 | the reason connectors in car audio are gold plated is because gold has decent conductivity but mroe importantly it's a noble metal, meaning it doesn't oxidize or tarnish, and it's soft or maliable, so it forms to whatever is pressed against it for a tighter connection. Cars and things in cars are subjected to a wide range of temperatures and humidities, and oxidation will destroy clean contacts. Gold prevents this, even though other metals have better conductivity. This is why most cables are multi-strand OFC inside teh insulation, then use gold plated connectors, sometimes with silver solder for conduction purposes. |
99questions Unregistered guest | Thanks for that guys. Ill be shore to change them i have about 6 of thoes and i have sone different ones to that arent on the site for speaker wire maybe ill take a picture or somthing later. Oh and say if i was to top my base and treble on my amp thats 1200 watts guess its only like 1000 cuz 1200 is peak would that be a bad thing? |
Gold Member Username: GlasswolfWisteria, Lane USA Post Number: 9967 Registered: Dec-03 | huh? whats the make and model of the amp, and what do you want to know? what size power wire you need? |
