Blaupunkt Coburg SQR 49
Username: Richyktm
Hello!
I need help... I have Blaupunkt Coburg SQR 49 radio with cassette player, but I lost a code.
Serial number: BP8470A3144597
Part number: 7648470013
Can someone please calculate code for this radio?
Username: Tech13
Post Number: 275
Richy
Username: Richyktm
Hi,
Try.....8591
Username: Richyktm
Good day
What is the procedure to enter the code once numbers are entered.
I tried 8591 and then press (>). Screen went back to (----) and stays like that for about 20 minutes before reverting to (code).
Radio in a Suzuki Vitara i bought.
Thanks for help.
Username: Decode_radio
Post Number: 953
Richy
Username: Richyktm
please check serial number
contakt me http://forum.kody-radio.pl
Username: Richyktm
Hi
Will double check my ser no asap.
What is the procedure to enter the code once numbers are entered ?
Richy
Username: Opelop
Post Number: 2719
https://www.radio-code.co.uk/Coburg-SQR49-code-entry-guide.html
If you would like to support the activity of the page,
you can leave a quick tip via paypal.
e-mail c.r.t.m.auto@gmail.com
Many thanks.
Username: Richyktm
Thank you opelop and TECH13, and decode radio
Turn on the radio, the display will show 'CODE'
Press preset [ 1 ] repeatedly for the first digit followed by [ station + ]
Press preset [ 2 ] repeatedly for the second digit followed by [ station + ]
Press preset [ 3 ] repeatedly for the third digit followed by [ station + ]
Press preset [ 4 ] repeatedly for the fourth digit followed by [ station + ]
Finally press the [ station + ] button to save.
I will try this once I confirm serial no and if someone can again please help with a correct working code.
Thanks
Username: Richyktm
Hello.
I have confirmed serial number is correct.
Code 8591 did not work.
Anybody able to help?
Username: Richyktm
Post Number: 7
Username: Richyktm
Post Number: 8
Hello.
No code worked. What are my options please???
Thanks
Username: Regrooster
Post Number: 11832
It will have to be taken into a Radio Decoding Workshop so that they can "read" the code inside the memory chip using special software
