Clarion pu-2294a need radio code can you help
Username: Wightsixty
Hi, battery went flat on car and radio code with car is incorrect as 2 attempts failed, only
one left before i get locked out.
numbers on side are
Cl040161049572C
C70000003222
number i have is 2294 when i go to enter the 9 radio says error ?
Thanks
Username: Iwos
Post Number: 501
dave
Hi,
TRY CODE .. 4456
Hi,
tried 4456 now have message PHONE on display, assume I am now locked out or is there something else I can try ? thanks
Hi ALMADIA,
thank you for code, for some reason radio is now working ? thanks again Dave
Username: Jonbrown188
Hi I need a code if you can help
cl040151021123c
pu2294a
many thanks
Username: Iwos
Post Number: 535
jon
Hi,
Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio
Hi C70000002646
Username: Iwos
Post Number: 551
jon
Hi,
TRY CODE .. 3214
