Clarion radio code needed
Username: Leger
Hi, I have a PU-2294-B(D) needing a code after messing with fuses trying to fix electic windows
CL0402Y0454718 same number on sticker on the top and on the metal on the side
Username: Titanum123
Post Number: 620
legers
Username: Leger
Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio.
http://www.forum-auto.com/pole-technique/equipement-automobile/sujet395936-5460. htm#t14836864
Username: Cybertooth99
I need a code number to bypass my Clarion system so that I can watch and play DVD Movies while driving, can anyone out there help me with that CODE?Upload
Username: Regrooster
Post Number: 11729
AJ
This is AGAINST THE LAW!...as well as dangerous!
