When adding a 2nd Battery?
Jerome
Ok my amp wont turn on.
I added a 2nd battery to the cargo area but its not grounded so thats why the amp wont turn on?
Also im using regular hose clapms for them
Username: Greeney1888
Maple Grove, MN United States
Post Number: 171
dont use a 2nd battery unless you have a HO Alternator, it will just put more strain on your stock alt. and battery. check your ground wiring again and look at these:http://www.wickedcases.com/caraudio/capacitors.html
http://www.wickedcases.com/caraudio/charging.html
http://www.betteraudio.com/geolemon/newmain/battcapalt/
http://www.bcae1.com/charging.htm
http://www.bcae1.com/chargin2.htm
http://www.wickedcases.com/caraudio/batteries.html
http://www.the12volt.com/info/recwirsz.asp
http://www.optimabatteries.com/
Jerome
HO?
Im using a 2nd battery because I have a 1985 jimmy and i dont want to put a strain on the alternator
Username: N2audio
Lawrence, Ks USA
Post Number: 681
HO - High output.
To get use out of a 2nd battery your alt has to be able to charge it. If your amp(s) is/are large enough to stress your alternator adding a 2nd battery will only make it worse.
Jerome
i have a 250.1 mon amp and i have to connect hte 2nd battery thats in the crago area to the alertenator?
