I have got a PPI 2240 amplifier, I need ONE 12" subwoofer, but don't know which one will help me get the most of the amplifier, please help!
PPI2240 amplifier-
Key Features Amplifier Type Dual Channel RMS Power at 4 Ohms .05 W x 120 RMS Power at 2 Ohms 1 W x 120 Performance Signal to Noise Ratio 120 dB THD at Rated RMS Power 5000 % Crossover / Equalizer Bass Boost Frequency 20 Hz Other Features Input Voltage 12 volt
um... you should power that to all you speekers... if you can... idk if that would even do anything... what you should do with that is give it back to who ever you got that amp from and make them give back you money... thats a POS amp
