Need Advice on System (Jonathan/Glasswolf/Anyone Else)
osc
Hi,
Please recommend some 6.5" speakers and an amplifier. Details below.
Current Setup:
1993 Honda Civic Dx Hatchback
Head Unit: Alpine CDA-9833
->Front Speakers: Stock 6.5" with a Maximum Mounting Depth of 2.775". Please recommend.
Rear Speakers: None (Don't plan on purchasing)
Subwoofer: Infinity 1030W 10"
->Amplifier: None. Please recommend.
*Front Speaker Budget: About $175 USD
I think I am going to be purchasing Infinity 62.5Is for my front stage, do you have any other recommendations on what type of speakers I should buy?
One problem that Crutchfield has told me is that I have a surface mounting height of 0.5" and that most speakers will not fit in my front panel. I measured the distance from the mounting surface to the panel and the distance I recorded was about 1.5". Will fitting the 62.5Is or any other recommended speaker be a problem with the 0.5" mounting height (as given by Crutchfield)?
*Amplifier Budget: About $350 USD
I have no clue as to what type or how many channels my amp should support, please make some suggestions.
Thanks for any advice.
